2434 | |
2411 | |
2240 | |
MfG Qasi
2219 | |
Server | Wunsch / Idee | mittel | Midi clock Input | Neu | 3.0 | | 30.04.2015 | 30.04.2015 | |
2149 | |
2123 | |
2057 | |
2043 | |
2004 | |
2002 | |
1982 | |
1864 | |
1863 | |
1862 | |
| Dimmer
-G12 |
-G1 |
D1 | 0
D2 | 25
-G2 |
D3 | -
D4 | 50
D5 | 75
D3 | 100
SDG = G12, Dimmer At 0 > 100
| Dimmer
-G12 | 0 > 100
-G1 |
D1 | 0
D2 | 33,33
-G2 |
D3 | 66,66
D4 | 100
| Dimmer | Color
-G12 | 0 > 100 |
-G1 | |
D1 | 0 |
D2 | 33,33 |
-G2 | | 0,0,0>255,0,0,0
D3 | 66,66 | 0,0,0
D4 | 100 | 255,0,0
| Dimmer
-G12 |
-G1 | -
D1 | -
D2 | -
-G2 |
D3 | -
D4 | 0
-G1 |
D1 |
D2 | 33,33
D3 | 66,66
D1 | 100
| Dimmer | Color
-G12 | | 0;0;0 > 255;0;0
-G1 | - |
D1 | - | 0;0;0
D2 | - | x;0;0
-G2 | |
D3 | - | y;0;0
D4 | 0 | 255;0;0
-G1 | |
D1 | |
D2 | 33,33 |
D3 | 66,66 |
D1 | 100 |
| Dimmer | Color | Iris
-G12 | | 0;0;0 > 255;0;0 |
-G1 | - | |
D1 | - | 0;0;0 |
D2 | - | x;0;0 |
-G2 | | |
D3 | - | y;0;0 |
D4 | 0 | 255;0;0 |
-G1 | | |
D1 | | | -
D2 | 33,33 | | 1
D3 | 66,66 | |
D1 | 100 | | 2
D4 | | | 0
-G1 | - | |
D1 | - | 0;0;0 |
D2 | - | x;0;0 |
-G2 | | |
D3 | - | y;0;0 |
D4 | 0 | 255;0;0 |
-G1 | | |
D1 | | | -
D2 | 33,33 | | 1
D3 | 66,66 | |
D1 | 100 | | 2
D4 | | | 0
D2 | | | | 0
-G2 | | | |
D1 | | | | 50
D2 | | | | 100
| Dimmer
-G12 | 100
-G1 | 100
D1 | 100
D2 | 100
-G2 | 100
D3 | 100
D4 | 100
(Detail Expanded)
-G12 | | | |
-G1 | - | | |
D1 | - | | |
D2 | - | | |
-G2 | | | |
D3 | - | | |
D4 | 0 | | |
-G1 | | | |
D1 | - | | |
D2 | 33,33 | | |
D3 | 66,66 | | |
D1 | 100 | | |
-G1 | | | |
-D1 | | 0;0;0 | | 0
-D2 | | x;0;0 | | 25
-G2 | | | |
-D3 | | y;0;0 | | 50
-D4 | | 255;0;0 | | 100
-D4, G1, D1 | | | 0 > 100 |
-D4 | | | 0 |
-G1 | | | |
-D1 | | | - |
-D2 | | | 50 |
-D1 | | | 100 |
(Detail, Collapsed)
+D4, G1, D1 | | | 0 > 100 |
(Device view, collapsed)
+D2 | 33,33 | x;0;0 | 50 | 25
+D3 | 66,66 | y;0;0 | | 50
+D4 | 0 | 255;0;0 | 0 | 100
Kommentare?
-D1 | 100 | 0;0;0 | 100 | 0
-D2 | 33,33 | x;0;0 | 50 | 25
-D3 | 66,66 | y;0;0 | | 50
-D4 | 0 | 255;0;0 | 0 | 100
1860 | |
1858 | |
1852 | |
1811 | |
1790 | |
1777 | |
$BeispielVariable
0<$BeispielPhase
-20<20
könnte ich dank
-$Fächer<$Fächer
1726 | |
1710 | |
1695 | |
1671 | |
1649 | |
1646 | |
1106 | |
880 | |
Hy,
Weiter ergänzen
Gruß Arne
812 | |
MIDI Show Control
653 | |
597 | |
596 | |
594 | |
593 | |
