5352 | |
GUI & Server | Fehlerbericht | Critical | Random Crashing 3.2.3 | Zufällige Abstürze 3.2.3 | Neu | 3.2.3 | | 24.06.2024 | 24.06.2024 | shween |
Task Description
This Task is to bring attention to the occurrences of random crashing experienced when programming the last project worked on. (v3.2.3)
I cannot pinpoint exactly what causes these issues but I have attached a LOG Export from the project. I hope it is not too late since the bugs occurred to export the LOG.
These crashes ranged anywhere from:
-Cue lists randomly not tracking correctly after some time programming inside the GUI.
-Tracking True / False Not applying to cue lists.
-Fixture Parameters not being able to be selected in the GUI or Programmer.
-Rare, but the whole GUI would sometimes lock up to the point I could not save a project before attempting to restart.
Generally, a full restart of the DMXControl Application would resolve the issues.
Sometimes, a full system restart was required.
Also, it seems the parameter: “Reset When Released” has absolutely no effect on Cue list release behavior.
I did notice this trend: that often when using Fanning Parameters (E.g. -90<>90 … 0>120>0 … 0<>90) in X/Y Moving head parameters, that DMXControl 3.2.3 would then behave extremely erratically, and eventually begin adding its own values in parameter fields, and eventually crash. When closing the application, I would then be presented with a messaged saying: “DMXControl Crashed - This should not have happened. Please Export Log to Bugtracker.”
Dedicated Show and Cue List playback seems extremely stable, it is only in heavy periods of programming that these crashes seem to occur.
Thank You.
Diese Aufgabe soll auf das Auftreten von zufälligen Abstürzen aufmerksam machen, die beim Programmieren des zuletzt bearbeiteten Projekts aufgetreten sind. (v3.2.3)
Ich kann nicht genau sagen, was diese Probleme verursacht, aber ich habe einen LOG-Export aus dem Projekt angehängt. Ich hoffe, es ist nicht zu spät, da die Fehler beim Exportieren des LOG aufgetreten sind.
Diese Abstürze reichten von:
-Cue-Listen werden nach einiger Zeit in der GUI zufällig nicht korrekt verfolgt.
-Tracking True / False Gilt nicht für Cue-Listen.
-Geräteparameter können nicht in der GUI oder im Programmierer ausgewählt werden.
-Selten, aber die gesamte GUI wurde manchmal bis zu dem Punkt gesperrt, an dem ich ein Projekt nicht speichern konnte, bevor ich versuchte, neu zu starten.
Im Allgemeinen würde ein vollständiger Neustart der DMXControl-Anwendung die Probleme beheben.
Manchmal war ein vollständiger Systemneustart erforderlich.
Außerdem scheint der Parameter: “Reset When Released” absolut keinen Einfluss auf das Freigabeverhalten der Cue-Liste zu haben.
Ich habe diesen Trend bemerkt: dass oft bei der Verwendung von Fanning-Parametern (z. B. -90<>90 … 0>120>0 … 0<>90) in X/Y-Moving-Head-Parametern, dass sich DMXControl 3.2.3 dann extrem unberechenbar verhält und schließlich anfängt, seine eigenen Werte in Parameterfeldern hinzuzufügen und schließlich abstürzt. Beim Schließen der Anwendung wurde mir dann eine Meldung angezeigt, die besagt: “DMXControl abgestürzt - Dies hätte nicht passieren dürfen. Bitte exportieren Sie das Protokoll in den Bugtracker.”
Die dedizierte Show- und Cue-List-Wiedergabe scheint extrem stabil zu sein, nur in schweren Programmphasen scheinen diese Abstürze aufzutreten.
Vielen Dank.
5349 | |
GUI | Wunsch / Idee | Low | Fenster "Update DDFs in Project" mit "Add Device" Fenst... | Unbestätigt | unbestimmt | | 24.06.2024 | 09.09.2024 | LightningBrothers |
Task Description
Führt man das Ticket FS#5348 gedanklich weiter, dann wäre im Zuge der Umsetzung der dort beschriebenen Funktion zu überlegen, ob das Fenster “Update DDFs in Project” von seiner Funktion her mit in das “Add device” Fenster übertragen wird.
Dies könnte ggf. bei der Neugestaltung des “Add device” Fensters im Rahmen des WPF-Umbaus erfolgen.
5348 | |
GUI & Server | Wunsch / Idee | Low | Explizites Einfügen aus Dateisystem ermöglichen obwohl ... | Unbestätigt | unbestimmt | | 24.06.2024 | 24.06.2024 | LightningBrothers |
Task Description
Wird ein DDF in einem Projekt bereits verwendet und man fügt weitere bzw. erneut Geräte ein, die dieses DDF verwenden, so wird dieses immer explizit aus dem Projekt herangezogen. Für ein bestehendes Projekt ist diese Regelung durchaus hilfreich, jedoch nicht, wenn man gerade ein neues DDF erstellt. Hier muss man dann immer erst die alte Version aus dem Projekt löschen, um dann die aktualisierte / korrigierte / ergänzte Version des DDFs ins Projekt einfügen zu können.
An dieser Stelle wäre es hilfreich, wenn man beim Hinzufügen explizit sagen könnte, dass die neuere Version aus dem Dateisystem verwendet werden soll. Dabei überschreibt diese Version dann die Version, die bis dato im Projekt existiert.
5347 | |
GUI & Server | Fehlerbericht | Low | DDF-Synatx: Einträge des Typs step werden bei rawranges... | Unbestätigt | 3.2.3 | | 24.06.2024 | 24.06.2024 | LightningBrothers |
Task Description
Jens-Peter und ich haben an einem DDF gearbeitet und dabei den folgenden Code eingefügt - so, wie er auch im Wiki dokumentiert ist.
<rawranges dmxchannel="0" name="Auto show" >
<step type="Off" mindmx="0" maxdmx="31" />
<range type="Show 1" mindmx="32" maxdmx="63" minval="0" maxval="100" />
<range type="Show 2" mindmx="64" maxdmx="95" minval="0" maxval="100" />
</rawranges>
Bei dieser Implementierung ist es so, dass der step-Eintrag im Device Control nicht auswählbar ist. Damit lässt sich die Funktion in Form der verschiedenen Automatik-Shows nicht abschalten. Hierfür muss aktuell der folgende Workaround herhalten:
<range type="Off" mindmx="0" maxdmx="0" minval="0" maxval="100" />
</rawranges>
Es wäre wie gesagt hilfreich, wenn der beschriebene Workaround nicht erforderlich wäre und direkt step-Einträge bei der Funktion rawranges unterstützt werden.
5335 | |
GUI & Server | Wunsch / Idee | Low | Export- und Import-Funktion für Anwendungseinstellungen | Unbestätigt | 3.2.3 | | 07.06.2024 | 07.06.2024 | LightningBrothers |
Task Description
Installiert man DMXControl 3 auf einem weiteren PC komplett neu, erfolgt der erste Start mit allen Standardeinstellungen für die Anwendung selbst als auch bei den Vorgaben für ein neues Projekt. Auch sind keine DMX-Interfaces konfiguriert.
Grundsätzlich ist es möglich, die verschiedenen Konfigurationsdateien vom ersten PC auf den neuen PC zu kopieren. Einfacher wäre es, wenn DMXControl 3 hier mit einer Export- und Importfunktion unterstützt, wie es auch andere Programme machen. Über diese Funktion könnte man sich dann auch so zwischendurch ein Backup seiner Einstellungen machen.
5331 | |
GUI & Server | Fehlerbericht | Medium | Bühnenansicht, Scheinwerfer, Fanning und Handlung insta... | Neu | 3.2.3 | | 17.05.2024 | 14.08.2024 | |
Task Description
5330 | |
GUI & Server | ToDo | Low | 64-Bit-Kernel und GUI erforderlich | Neu | 3.3 RC x | | 17.05.2024 | 21.05.2024 | |
Task Description
5327 | |
GUI & Server | Wunsch / Idee | Low | Programm- und Interface-Konfiguration beim Speichern de... | Unbestätigt | unbestimmt | | 13.05.2024 | 13.05.2024 | LightningBrothers |
Task Description
5315 | |
TimecodePlayer | Wunsch / Idee | Low | Aktuelle Position der Maus in der Zeitachse anzeigen | Unbestätigt | 3.3 Beta x | | 02.05.2024 | 02.05.2024 | LightningBrothers |
Task Description
5311 | |
TimecodePlayer | Fehlerbericht | Medium | Timecode wird bei Wiedergabestart in der Show nicht meh... | Unbestätigt | 3.3 RC x | | 28.04.2024 | 08.11.2024 | LightningBrothers |
Task Description
5310 | |
TimecodePlayer | Fehlerbericht | Low | Häufiges Aufrufen von Cuelists mit Timecode-Trigger füh... | Unbestätigt | 3.3 RC x | 3.3.x | 27.04.2024 | 08.11.2024 | LightningBrothers |
Task Description
5309 | |
GUI & Server | Wunsch / Idee | Low | Ändern von Special Cues ermöglichen | Unbestätigt | 3.2.3 | | 27.04.2024 | 27.04.2024 | LightningBrothers |
Task Description
5308 | |
TimecodePlayer | Wunsch / Idee | Low | Direktes Tauschen / Ersetzen von Cuelists im Cuelist-Tr... | Unbestätigt | 3.3 RC x | | 27.04.2024 | 27.04.2024 | LightningBrothers |
Task Description
5307 | |
TimecodePlayer | Wunsch / Idee | Low | Hinzufügen von Special cues anbieten | Unbestätigt | 3.3 RC x | | 27.04.2024 | 27.04.2024 | LightningBrothers |
Task Description
5306 | |
TimecodePlayer | Wunsch / Idee | Low | Möglichkeit zum Verschieben von Cuelists in einen ander... | Unbestätigt | 3.3 RC x | | 27.04.2024 | 27.04.2024 | LightningBrothers |
Task Description
5300 | |
GUI | Fehlerbericht | Low | Effektvisualizer aktualisiert sich bei Verwendung von C... | Unbestätigt | 3.3 RC x | | 05.04.2024 | 05.04.2024 | LightningBrothers |
Task Description
5299 | |
Softdesk | Wunsch / Idee | Low | Executorenzüge ins softdeck ziehen | Zugeteilt | 3.3 RC x | | 05.04.2024 | 29.08.2026 | |
Task Description
5298 | |
Executoren | Wunsch / Idee | Low | Executorzüge flexibler gestalten | Neu | 3.3 RC x | | 05.04.2024 | 23.04.2024 | |
Task Description
5297 | |
TimecodePlayer | Wunsch / Idee | Low | Timecodeplayer Abspielgeschwindigkeit | Neu | 3.3 RC x | | 05.04.2024 | 05.04.2024 | |
Task Description
5295 | |
TimecodePlayer | Wunsch / Idee | Low | Linker bereich des Timecodeplayer Sortierbar machen evt... | Neu | 3.3 RC x | | 05.04.2024 | 05.04.2024 | |
Task Description
5294 | |
TimecodePlayer | Wunsch / Idee | Low | Tabellenkopf und tabstops Timecodeplayer (spur fixiere... | Neu | 3.3 RC x | | 05.04.2024 | 05.04.2024 | |
Task Description
Wunsch für den Timecodeplayer
und
5291 | |
Softdesk | Wunsch / Idee | Low | Schriftgröße CueList Monitor ändern | Neu | 3.2.3 | | 02.04.2024 | 02.04.2024 | |
Task Description
Hallo liebe Entwickler,
Viele Grüße, Dirk.
5288 | |
Server | Wunsch / Idee | Low | Mehrere separate Frostfilter zulassen | Neu | 3.2.3 | | 25.03.2024 | 23.07.2024 | dPi |
Task Description
<frost dmxchannel="0">
</frost>
<frost dmxchannel="1">
</frost>
5285 | |
GUI & Server | Fehlerbericht | High | ParameterMaster können bei Frequency von Positionseffek... | Neu | 3.3 RC x | | 23.03.2024 | 05.08.2024 | IlluminateXperience |
Task Description
5282 | |
GUI & Server | Wunsch / Idee | Low | Parameter-/ Speed-Master in Release-Time | Neu | 3.2.3 | | 14.03.2024 | 15.03.2024 | Beni200 |
Task Description
5281 | |
GUI & Server | Wunsch / Idee | Low | Fanning Operatoren in Release-Time | Neu | 3.2.3 | | 14.03.2024 | 04.04.2024 | Beni200 |
Task Description
5278 | |
Softdesk | Wunsch / Idee | Low | Softdesk Menue erweitern | Neu | 3.2.3 | | 12.03.2024 | 12.03.2024 | steff |
Task Description
Bilder im Anhang.
5277 | |
Softdesk | Wunsch / Idee | Low | Relative Positionen beibehalten wenn im Softdesk mehrer... | Bestätigt | 3.2.3 | | 12.03.2024 | 23.08.2026 | steff |
Task Description
5270 | |
GUI & Server | Wunsch / Idee | Low | Umschalten zwischen Stage Views mit dem IA | Neu | 3.2.3 | | 04.03.2024 | 11.02.2025 | steff |
Task Description
5269 | |
GUI & Server | Wunsch / Idee | Low | Umschalten zwischen Soft-Desks mit dem IA | Neu | 3.2.3 | | 04.03.2024 | 11.02.2025 | steff |
Task Description
5267 | |
GUI & Server | Wunsch / Idee | Low | Cuelist Node ist Anzeige der gewählten Cuelist in den P... | Usability Relevant | 3.2.3 | 3.4 | 03.03.2024 | 06.04.2025 | steff |
Task Description
5260 | |
InputAssignment | Wunsch / Idee | Low | Shortcuts CTRL-C und CTRL-V funktionieren nicht im Impu... | Zugeteilt | 3.2.3 | 3.4 | 12.02.2024 | 12.03.2024 | bernd |
Task Description
5258 | |
GUI & Server | Fehlerbericht | Medium | Chaser filter restart with previous state | Auf User warten | 3.3 RC x | | 12.02.2024 | 22.10.2024 | |
Task Description
Error Description
Expected behavior
Notes
5257 | |
Softdesk | Wunsch / Idee | Low | Cuelist Monitor und Touch Bildschirm | Neu | 3.2.3 | | 11.02.2024 | 24.02.2024 | Joel09 |
Task Description
Mit freundlichen Grüßen Joel
5254 | |
InputAssignment | Wunsch / Idee | Low | InpAss: Fade Node soll RGB-Werte faden können | Neu | 3.3 RC x | | 05.02.2024 | 07.02.2024 | patme |
Task Description
5253 | |
GUI & Server | Wunsch / Idee | Low | Bei neu anlegen eines Projektes wird (New Project) nich... | Neu | 3.3 RC x | | 28.01.2024 | 03.03.2024 | steff |
Task Description
5251 | |
GUI & Server | Wunsch / Idee | Low | Projektstatistik | Unbestätigt | 3.2.3 | | 25.01.2024 | 25.01.2024 | LightningBrothers |
Task Description
Devices
Device Groups
Cues
Presets
Cuelists
Cuelist Groups
Timecodeshows
5250 | |
GUI & Server | Wunsch / Idee | Low | Eingebauter Benchmark | Unbestätigt | 3.2.3 | | 24.01.2024 | 24.01.2024 | JPK |
Task Description
Dauer Programmstart
5248 | |
TimecodePlayer | Fehlerbericht | Low | Timecode Player - waveform displays incorrectly at high... | Zugeteilt | 3.3 RC x | TBD (UIS) | 21.01.2024 | 08.11.2024 | philbearman |
Task Description
See this video:
5243 | |
Plugin | Fehlerbericht | Medium | Modbus TCP Coil Eingang wird nicht im InputAssignment n... | Neu | 3.2.3 | | 08.01.2024 | 12.01.2024 | |
Task Description
5240 | |
TimecodePlayer | Wunsch / Idee | Low | Addiontal fade curves for transitions of cues in cuelis... | Neu | 3.3 RC x | | 04.01.2024 | 04.01.2024 | wide |
Task Description
The image looks like this.
5236 | |
GUI & Server | Fehlerbericht | Critical | DMXC 3.3 RC1 öffnet nach GUI-Crash (IA) vorhandenes Pro... | Neu | 3.3 RC x | | 02.01.2024 | 05.08.2024 | djquickwilli |
Task Description
02:03:15 WARN ProjectManager - Error when loading Project 2024_330_V001_Basisprojekt: Der Vorgang wurde erfolgreich beendet.
System.ComponentModel.Win32Exception (0x80004005): Der Vorgang wurde erfolgreich beendet.
5235 | |
InputAssignment | Fehlerbericht | Very Low | Text überschneidet sich | Zugeteilt | 3.2.3 | 3.4 | 31.12.2023 | 07.04.2025 | EDER |
Task Description
5232 | |
TimecodePlayer | Wunsch / Idee | Low | Wenn Button für Pause verwendet wurde, auch mit Pause-B... | Neu | 3.3 RC x | | 30.12.2023 | 01.01.2024 | steff |
Task Description
5230 | |
GUI | Wunsch / Idee | Low | Improvements to keyboard shortcuts for faster workflow | Neu | 3.3 RC x | | 30.12.2023 | 01.08.2024 | philbearman |
Task Description
Hi all,
* “GO” on cuelist
All the best, Phil
5227 | |
TimecodePlayer | Wunsch / Idee | Low | About shortcuts for horizontal scrolling in timecode pl... | Neu | 3.3 RC x | | 29.12.2023 | 01.08.2024 | |
Task Description
5225 | |
Softdesk | Fehlerbericht | Medium | Dropdown Menü steckt fest | Neu | 3.3 RC x | | 28.12.2023 | 30.12.2023 | EDER |
Task Description
5224 | |
GUI | Fehlerbericht | Low | Cue Verschiebung mit Maus teilweise nicht möglich | Neu | 3.2.3 | 3.3.x | 28.12.2023 | 01.08.2024 | EDER |
Task Description
5223 | |
Softdesk | Fehlerbericht | Very Low | Slider überschreitet Softdesk Grenze | Neu | 3.3 RC x | | 28.12.2023 | 28.12.2023 | EDER |
Task Description
Email: kingOfCrochet@web.de
5219 | |
TimecodePlayer | Wunsch / Idee | Low | Neue Cue an aktueller Position des Wiedergabemarkers ei... | Unbestätigt | 3.3 Beta x | | 26.12.2023 | 27.04.2024 | LightningBrothers |
Task Description
