5235 | |
2922 | |
4775 | |
4112 | |
5002 | |
5248 | |
See this video:
5249 | |
Issue 1:
Issue 2:
See this video:
5311 | |
5247 | |
5297 | |
4678 | |
4809 | |
3201 | |
Hallo liebe DMXControler,
LG Jelu
5137 | |
3435 | |
2910 | |
4592 | |
3409 | |
5058 | |
4334 | |
3105 | |
4088 | |
4167 | |
3308 | |
3145 | |
Favoriten für Presets anlegen
4974 | |
5165 | |
.NET 4.8 found!
ASP.NET Core 6 (x32) found!
ASP.NET Core 6 (x64) found!
XNA 4.0 found!
Windows Installer 3.1 found!
Lade .NET Desktop (x86)...
Lade .NET Desktop (x64)...
Application: Umbra.exe
Architecture: x64
4331 | |
5269 | |
5270 | |
5120 | |
4398 | |
4852 | |
4019 | |
3226 | |
4241 | |
2709 | |
4380 | |
3338 | |
3339 | |
4849 | |
1777 | |
$BeispielVariable
0<$BeispielPhase
-20<20
könnte ich dank
-$Fächer<$Fächer
5285 | |
3076 | |
Stand jetzt:
mm:ss
hh:mm:ss
15m32s
.z
.zz
.zzz
ss.z[zz] (auch >59)
mm:ss.z[zz]
hh:mm:ss.z[zz]
Beste Grüße, der Lichtheini
3966 | |
4466 | |
3296 | |
5265 | |
3979 | |
3645 | |
