834 | |
5080 | |
5095 | |
1597 | |
2909 | |
3901 | |
4176 | |
1497 | |
5225 | |
2002 | |
2004 | |
5216 | |
5142 | |
5236 | |
4861 | |
3630 | |
Cuelist Group Number
Executor Number
Executor Page Number
4994 | |
4527 | |
5308 | |
1067 | |
4372 | |
4976 | |
4590 | |
GUI | Wunsch / Idee | niedrig | Device Control merkt sich zuletzt genutztes Farbmodell | Unbestätigt | 3.2.2 | | 25.07.2021 | 25.07.2021 | LightningBrothers |
3569 | |
4336 | |
2430 | |
<zoom dmxchannel="19" >
<rotation dmxchannel="20" >
</rotation>
<index dmxchannel="20" />
</range>
</zoom>
4246 | |
3919 | |
<static>30</static>
</electrical>
4818 | |
4277 | |
3527 | |
3903 | |
3264 | |
Block 1, Szene 1
Block 1, Szene 2
Block 1, Szene 3
Block 2, Szene 1
Block 2, Szene 2
Block 3, Szene 1
Block 3, Szene 2
Block 3, Szene 3
Block 3, Szene 4
4378 | |
4159 | |
3974 | |
5023 | |
490 | |
597 | |
479 | |
1710 | |
478 | |
Cue 1 | manual | | |
Cue 2 | manual | | |
Cue 3 | follow | 1 | |
Cue 4 | follow | 1 | |
Cue 5 | follow | 1 | |
Cue 7 | manual | | |
492 | |
2975 | |
596 | |
491 | |
1106 | |
4660 | |
3591 | |
4870 | |
