3557 | |
Danke für Feedback.
3919 | |
<static>30</static>
</electrical>
4060 | |
Kernel
GUI
Parametername: prop
Parametername: prop
Parametername: prop
Parametername: prop
4246 | |
4258 | |
4291 | |
4293 | |
LG Paul
4427 | |
4638 | |
4849 | |
5142 | |
5150 | |
Was habe ich gemacht?
5211 | |
5249 | |
Issue 1:
Issue 2:
See this video:
5284 | |
5285 | |
5286 | |
Soweit so gut.
5287 | |
5313 | |
3884 | |
4046 | |
5236 | |
5259 | |
