4098 | |
Meine Vorschläge dazu:
4099 | |
4101 | |
4110 | |
4112 | |
4116 | |
4117 | |
4118 | |
4122 | |
4133 | |
4141 | |
4142 | |
4150 | |
4151 | |
4152 | |
Cuelists
Cuelist Groups
Devices
Device Groups
Group Number (Group Master)
(Executor
Executor Pages)
Electricity
4156 | |
4157 | |
4159 | |
4162 | |
4167 | |
4171 | |
4173 | |
4174 | |
4175 | |
4176 | |
4180 | |
4181 | |
4188 | |
4190 | |
4196 | |
4202 | |
4205 | |
4207 | |
<prism dmxchannel="0">
</prismrotation>
</prism>
<prism dmxchannel="2">
</prismrotation>
</prism>
4208 | |
abbilden und ansprechen.
4209 | |
4213 | |
4222 | |
9. Async Ansicht mit Cancel
4225 | |
4226 | |
4230 | |
Wünsche:
4231 | |
4232 | |
ColorGrid –> Color Grid
4233 | |
4235 | |
4236 | |
4237 | |
Peer hat ja schon begonnen.
4238 | |
4241 | |
4243 | |
4246 | |
