728 | |
726 | |
725 | |
677 | |
- RGB (Beam 1-3)
- Position
- Global
- Position
- Beam 2
- RGB
- Beam 3
- RGB
653 | |
616 | |
614 | |
599 | |
597 | |
596 | |
595 | |
594 | |
593 | |
591 | |
548 | |
492 | |
491 | |
490 | |
479 | |
478 | |
Cue 1 | manual | | |
Cue 2 | manual | | |
Cue 3 | follow | 1 | |
Cue 4 | follow | 1 | |
Cue 5 | follow | 1 | |
Cue 7 | manual | | |
353 | |
303 | |
280 | |
