4334 | |
4335 | |
4319 | |
4446 | |
Mein Änderungswunsch:
3925 | |
3527 | |
5227 | |
5247 | |
5294 | |
Wunsch für den Timecodeplayer
und
5295 | |
5297 | |
5137 | |
3201 | |
Hallo liebe DMXControler,
LG Jelu
5312 | |
5131 | |
5317 | |
4809 | |
5248 | |
See this video:
5249 | |
Issue 1:
Issue 2:
See this video:
5073 | |
5077 | |
5212 | |
5216 | |
5219 | |
TimecodePlayer | Wunsch / Idee | niedrig | Neue Cue an aktueller Position des Wiedergabemarkers ei... | Unbestätigt | 3.3 Beta x | | 26.12.2023 | 27.04.2024 | LightningBrothers |
5306 | |
5307 | |
5308 | |
5310 | |
5313 | |
5315 | |
5232 | |
5240 | |
The image looks like this.
5150 | |
Was habe ich gemacht?
5165 | |
.NET 4.8 found!
ASP.NET Core 6 (x32) found!
ASP.NET Core 6 (x64) found!
XNA 4.0 found!
Windows Installer 3.1 found!
Lade .NET Desktop (x86)...
Lade .NET Desktop (x64)...
Application: Umbra.exe
Architecture: x64
