5215 | |
5216 | |
5217 | |
5218 | |
5219 | |
TimecodePlayer | Wunsch / Idee | niedrig | Neue Cue an aktueller Position des Wiedergabemarkers ei... | Unbestätigt | 3.3 Beta x | | 26.12.2023 | 29.12.2023 | LightningBrothers |
5221 | |
5223 | |
Email: kingOfCrochet@web.de
5224 | |
5225 | |
5227 | |
5228 | |
5230 | |
Hi all,
* “GO” on cuelist
All the best, Phil
5232 | |
5234 | |
5235 | |
5236 | |
5240 | |
The image looks like this.
5241 | |
5243 | |
5245 | |
(siehe Screenshot)
5247 | |
5248 | |
See this video:
5249 | |
Issue 1:
Issue 2:
See this video:
5250 | |
Dauer Programmstart
5251 | |
Devices
Device Groups
Cues
Presets
Cuelists
Cuelist Groups
Timecodeshows
5253 | |
5254 | |
5257 | |
Mit freundlichen Grüßen Joel
5258 | |
Error Description
Expected behavior
Notes
5259 | |
5260 | |
5265 | |
5267 | |
5269 | |
5270 | |
5271 | |
5273 | |
5274 | |
5276 | |
3.3 RC2
5277 | |
5278 | |
Bilder im Anhang.
5281 | |
5282 | |
5283 | |
5284 | |
5285 | |
5286 | |
Soweit so gut.
5287 | |
5288 | |
<frost dmxchannel="0">
</frost>
<frost dmxchannel="1">
</frost>
5289 | |
