595 | |
677 | |
- RGB (Beam 1-3)
- Position
- Global
- Position
- Beam 2
- RGB
- Beam 3
- RGB
353 | |
591 | |
593 | |
596 | |
597 | |
599 | |
811 | |
MIDI Timecode
812 | |
MIDI Show Control
1810 | |
1862 | |
| Dimmer
-G12 |
-G1 |
D1 | 0
D2 | 25
-G2 |
D3 | -
D4 | 50
D5 | 75
D3 | 100
SDG = G12, Dimmer At 0 > 100
| Dimmer
-G12 | 0 > 100
-G1 |
D1 | 0
D2 | 33,33
-G2 |
D3 | 66,66
D4 | 100
| Dimmer | Color
-G12 | 0 > 100 |
-G1 | |
D1 | 0 |
D2 | 33,33 |
-G2 | | 0,0,0>255,0,0,0
D3 | 66,66 | 0,0,0
D4 | 100 | 255,0,0
| Dimmer
-G12 |
-G1 | -
D1 | -
D2 | -
-G2 |
D3 | -
D4 | 0
-G1 |
D1 |
D2 | 33,33
D3 | 66,66
D1 | 100
| Dimmer | Color
-G12 | | 0;0;0 > 255;0;0
-G1 | - |
D1 | - | 0;0;0
D2 | - | x;0;0
-G2 | |
D3 | - | y;0;0
D4 | 0 | 255;0;0
-G1 | |
D1 | |
D2 | 33,33 |
D3 | 66,66 |
D1 | 100 |
| Dimmer | Color | Iris
-G12 | | 0;0;0 > 255;0;0 |
-G1 | - | |
D1 | - | 0;0;0 |
D2 | - | x;0;0 |
-G2 | | |
D3 | - | y;0;0 |
D4 | 0 | 255;0;0 |
-G1 | | |
D1 | | | -
D2 | 33,33 | | 1
D3 | 66,66 | |
D1 | 100 | | 2
D4 | | | 0
-G1 | - | |
D1 | - | 0;0;0 |
D2 | - | x;0;0 |
-G2 | | |
D3 | - | y;0;0 |
D4 | 0 | 255;0;0 |
-G1 | | |
D1 | | | -
D2 | 33,33 | | 1
D3 | 66,66 | |
D1 | 100 | | 2
D4 | | | 0
D2 | | | | 0
-G2 | | | |
D1 | | | | 50
D2 | | | | 100
| Dimmer
-G12 | 100
-G1 | 100
D1 | 100
D2 | 100
-G2 | 100
D3 | 100
D4 | 100
(Detail Expanded)
-G12 | | | |
-G1 | - | | |
D1 | - | | |
D2 | - | | |
-G2 | | | |
D3 | - | | |
D4 | 0 | | |
-G1 | | | |
D1 | - | | |
D2 | 33,33 | | |
D3 | 66,66 | | |
D1 | 100 | | |
-G1 | | | |
-D1 | | 0;0;0 | | 0
-D2 | | x;0;0 | | 25
-G2 | | | |
-D3 | | y;0;0 | | 50
-D4 | | 255;0;0 | | 100
-D4, G1, D1 | | | 0 > 100 |
-D4 | | | 0 |
-G1 | | | |
-D1 | | | - |
-D2 | | | 50 |
-D1 | | | 100 |
(Detail, Collapsed)
+D4, G1, D1 | | | 0 > 100 |
(Device view, collapsed)
+D2 | 33,33 | x;0;0 | 50 | 25
+D3 | 66,66 | y;0;0 | | 50
+D4 | 0 | 255;0;0 | 0 | 100
Kommentare?
-D1 | 100 | 0;0;0 | 100 | 0
-D2 | 33,33 | x;0;0 | 50 | 25
-D3 | 66,66 | y;0;0 | | 50
-D4 | 0 | 255;0;0 | 0 | 100
479 | |
491 | |
1574 | |
478 | |
Cue 1 | manual | | |
Cue 2 | manual | | |
Cue 3 | follow | 1 | |
Cue 4 | follow | 1 | |
Cue 5 | follow | 1 | |
Cue 7 | manual | | |
490 | |
492 | |
594 | |
725 | |
726 | |
728 | |
1106 | |
1649 | |
1710 | |
1811 | |
1858 | |
1860 | |
1863 | |
1864 | |
2975 | |
653 | |
838 | |
GUI | Bug | niedrig | Layout, Fensterpositionen | geschlossen | Alpha 3 | | 20.04.2012 | 31.12.2012 | fisl |
Fenter auf zweiten Bildschirm. Speichern Bildschirm deaktivieren Laden Fenster weg.
Zusätzlich sollte auch der WindowState (max/minimiert) wiederhergestellt werden. Ausgedockte Fenster sollten in der Taskleiste angezeigt werden
1818 | |
StageView | Wunsch / Idee | niedrig | Doppelklick auf Icon im LiveView -> Lumos | geschlossen | 3.2 Alpha x | 3.2 | 05.11.2013 | 09.01.2019 | fisl |
Wie wäre es, wenn ein Doppelklick im LiveView sich wie der Button Lumos verhalten würde? Probleme mit Highlight? Ggf später Lowlight?
742 | |
Server | Bug | niedrig | Attachables, Rechtangle Amplitude hängt | geschlossen | Alpha 3 | | 04.02.2012 | 15.03.2012 | fisl |
Wackelt man ca. 10s am Amplitude Fader vom Rectangle (Andere noch nicht getestet) springt der Wert auf 0 und bleibt ca. 10s dort. Auch die DMX Ausgabe wird nicht mehr aktualisiert
851 | |
GUI | Bug | niedrig | InputLayer beim Beenden | geschlossen | Alpha 3 | | 01.05.2012 | 31.12.2012 | fisl |
Gerade beim Beenden augetreten: Nur versucht DMX In auf Intensity zu legen, sonst nix. Input Fenster war offen.
2012-05-01 21:50:55,781 [1] FATAL LumosGUI - Unhandled Exception: Die Sequenz enthält mehrere übereinstimmende Elemente.
System.InvalidOperationException: Die Sequenz enthält mehrere übereinstimmende Elemente.
bei System.Linq.Enumerable.SingleOrDefault[TSource](IEnumerable`1 source, Func`2 predicate)
bei Lumos.GUI.Windows.InputLayer.InputLayerForm.RemoveListenerNode(String InputListenerID) in D:\dmxc3\Lumos\LumosGUI\Windows\InputLayer\InputLayerForm.cs:Zeile 254.
420 | |
GUI | Fehlerbericht | mittel | Presets, Fehlverhalten von Append | geschlossen | 0.6 | | 24.05.2011 | 07.06.2011 | fisl |
Szenerio 1 (korrekt):
Dimmer 1 At 70
Store Preset
Clear
Laden: Dimmer 1 At 70
Clear
Dimmer 1 At 30
Append
Clear
Szenario 2 (falsch):
Dimmer 1 At 70
Store Preset
Clear
Clear
Dimmer 1 + 2 At 30
Append
Clear
Laden: Dimmer 1 + 3 At 30, erwartet aber: Dimmer 1 At 70, Dimmer 2 At 30
540 | |
GUI | Fehlerbericht | mittel | Cuelist, Zelle editieren | geschlossen | 0.6 | | 10.07.2011 | 20.05.2013 | fisl |
Editiert man eine Zelle, z.B. Trigger Value verlässt man mit den Pfeiltasten die Zelle, wenn der Cursor am Rand ist. Ist der Cursor am Ende des Textes, oder die Zelle leer, löscht “del” das Cue.
371 | |
GUI | Bug | niedrig | Device Manager, immer Autogenerate Group | geschlossen | 0.6 | | 07.05.2011 | 23.06.2011 | fisl |
Im Device Manager funktioniert die Auswahl, ob eine Gruppe angelegt werden soll nicht. Am Anfang ist das Häkchen nicht gesetzt. Sobalb man auf OK klickt, wird das Häkchen automatisch gesetzt. Setzt man es per Hand, wird auch eine Gruppe angelegt.
Das Häkchen sollte von anfang an gesetzt sein (oder nicht, besser konfigurierbar) und dann beim klick auf OK die gewünscht Aktion ausführen.
379 | |
GUI | Wunsch / Idee | niedrig | Project Explorer, Zugriff auf Device Properties | geschlossen | 0.6 | | 08.05.2011 | 01.09.2011 | fisl |
Bis jetzt können Geräteeigenschaften nur geändert werden, wenn das Gerät unter Devices markiert wird. Es sollte möglich sein, überall, wo das Gerät auftaucht, z.B. unter Groups oder LiveView die Gräteeigenschaften direkt zu verändern.
380 | |
GUI | Wunsch / Idee | niedrig | Project Explorer, benutzen der Einträge überall im Proj ... | geschlossen | 0.6 | | 08.05.2011 | 20.11.2011 | fisl |
Momentan ist es so, dass wenn ich: Geräte zum Live View hinzufügen will, ich diese aus der Gruppe Devices markieren muss. Es sollte möglich sein, Devices, die in einer Gruppe angeordnet sind zum Live View hinzufügen zu können.
382 | |
GUI | Wunsch / Idee | niedrig | Project Explorer, Ordner als Selektionshilfe nutzen | geschlossen | 0.6 | | 08.05.2011 | 04.04.2012 | fisl |
Will ich momentan Geräte, die in einem Ordner angeordnet sind zum Live View hinzufügen, muss ich diese einzeln markieren und dann hinzufügen. Gleiches gilt für Gruppen, die in Ordnern angeordnet sind. Es sollte möglich sein den Ordner zu nutzen, um den ganzen Inhalt (dieses Ordners, z.B. 4 Gruppen) zum Live View hinzuzufügen, ohne diese Gruppen extra zu markieren.
674 | |
Server | Wunsch / Idee | niedrig | Gruppen in Gruppen | geschlossen | unbestimmt | 3.3 | 11.12.2011 | 10.01.2022 | fisl |
Man hat die Möglichkeit Gruppen erneut zu gruppieren. Die Tiefe ist auf unbegrenzt, ausgenommen Schleifen Auf diese oberste Gruppe koennen auch Effekte gelegt werden. Ist ein Gerät in mehreren Gruppen, werden nur die Werte aus der ersten Gruppe verwendet.
2967 | |
StageView | Fehlerbericht | niedrig | Verschieben von einem Icon | geschlossen | 3.2 Alpha x | | 09.11.2017 | 10.11.2017 | fisl |
Ich möchte ein Icon verschieben. Das Icon ist nicht selektiert. Ich drücke die linke Maustaste, der Cursor befindet sich zu diesem Zeitpunkt bereits auf dem Icon. Ich ziehe den Cursor.
Es wird ein Selektionsrahmen gezeichnet. Eigentlich sollte das Icon verschoben werden.
Wenn das Icon bereits selektiert ist und ich dann klicke und ziehe funktioniert es wie erwartet.
845 | |
Server | Bug | hoch | 2 Gobowheels | geschlossen | Alpha 3 | | 25.04.2012 | 29.04.2012 | fisl |
Hat ein Geraet 2 Gobowheels, existieren auf dem 2ten Gobowheel Gobos mit dem GobowheelIndex -1
AbstractDeviceProperty.cs L. 104
public IPropertyValue getValueInstance(object value)
IPropertyValue p = getValueInstance();
p.Value = value;
return p;
Der Parameter value hat GobowheelIndex -1, weil im GoboHandlerNode.cs in L. 75 fuer alle nicht ersten Gobowheels das statische Gobo.OPEN benutzt.
Gobo wheelGobo = Gobo.OPEN;
if (g.GobowheelIndex == i)
wheelGobo = g;
IPropertyValue wheelValue = this.GoboProperty.Gobowheels[i].getValueInstance(wheelGobo);
358 | |
GUI | Bug | mittel | Auto-Reconnect funktioniert manchmal nicht | geschlossen | 0.6 | | 05.05.2011 | 03.10.2012 | fisl |
Kommt dann nur eine Fehlermeldung “Error when Auto Connecting to Server. Retry?” Dann muss ich manuell Verbinden, oder die GUI neustarten.
Im Log steht “System.Runtime.Remoting.RemotingException: Failed to create an IPC Port: Access is denied.”
471 | |
Server | Bug | mittel | Cuelist, bliebt bei falschem Tastendruck hängen | geschlossen | 0.6 | | 19.06.2011 | 04.04.2012 | fisl |
Beta 2
3 Cues, Cue 1 Chan 1 At Full Cue 2 Chan 2 At 70 Cue 3 Chan 3 At Full
Rest ist auf dem Video zu erkennen.
Die weiteren Fehler, die zu erkennen sind in gesonderten Tickets.
745 | |
Server | Fehlerbericht | mittel | Attachables, Parameter ändern | geschlossen | Alpha 3 | | 11.02.2012 | 02.09.2015 | fisl |
Ändert man einen Parameter, ändern sich die Ausgabewerte sofort. Sinus auf Tilt. Ich ändere die Frequenz → Sprung der Ausgabewerte. Es dürften sich die Werte durch ändern von Parametern nicht verändern.
Warum das so ist, ist ja klar. Nur ich bin der Meinung wir können das nicht so lassen, denn während der Vorstellung muss auch mal was geändert werden. Auch beim programmieren ist das kein schönes Verhalten.
502 | |
Server | Bug | niedrig | Cuelist, RTC Trigger 2 oder mehr abgelaufenen Einträgen | geschlossen | 0.6 | | 21.06.2011 | 08.02.2013 | fisl |
Cuelist bleibt hängen, wenn 2 oder mehre abgelaufene Einträge vorhanden und nicht der erste gestartet wird.
Cuelist, 2 Cues beide Trigger RTC abgelaufen den zweiten Eintrag doppelklicken und während oder nach dem einblenden GO klicken
679 | |
GUI | Bug | niedrig | Property Grid, Effektansicht wird nicht aktualisiert | geschlossen | Alpha 3 | | 19.12.2011 | 26.12.2011 | fisl |
-Unter Tab Properties Effekt hinzufügen, löschen, dann auf Tab Effects wechseln. Effekt immernoch da. Analog funktioniert das auch für die umgekehrte Richtung. -Analog gilt FS#641 auf für das Effect Tab. -Wird der letzte Effekt gelöscht, bleiben Einträge zu den Geräten/Beam/Property erhalten obwohl kein Effekt mehr dran hängt → erst nach de- und erneuter Selektion wird nichts mehr angezeigt. ← Wenn FS#680 eingebaut wird, könnte das ganz nützlich sein?
