3533 | |
3296 | |
4060 | |
Kernel
GUI
Parametername: prop
Parametername: prop
Parametername: prop
Parametername: prop
4772 | |
5065 | |
5080 | |
4276 | |
5058 | |
3832 | |
4334 | |
3149 | |
Art des Plugins (Kernel, GUI)
Author
Plugin-Version
kompatible DMXControl-Version
3136 | |
4649 | |
3373 | |
Geprüft mit Build 1602
3360 | |
Create Cuelist
Add Device
Create Cuelist Group
Create Device Group
Create Executor Page
Add Softdesk
Add Power Source
Create Stage View
Create Item List
Import Files
3607 | |
4499 | |
InputAssignment | Wunsch / Idee | niedrig | Input und Output eines Buttons etc. in Graphenansicht "... | Usability Relevant | 3.2.2 | | 24.04.2021 | 24.04.2021 | LightningBrothers |
3302 | |
3146 | |
5150 | |
Was habe ich gemacht?
2109 | |
4848 | |
3463 | |
2909 | |
3738 | |
Go, Pause, Stop
Add Cue, Edit, Up, Down,
Mode, Options, Autoscroll
5314 | |
5316 | |
5218 | |
5265 | |
5271 | |
5152 | |
4803 | |
5148 | |
5211 | |
4942 | |
4766 | |
5000 | |
4853 | |
3662 | |
4852 | |
2829 | |
5027 | |
4785 | |
3569 | |
3526 | |
4435 | |
InputAssignment | ToDo | niedrig | Inputs / Outputs von Nodes farblich hervorheben, die ei... | Zugeteilt | 3.3 Alpha x | | 05.04.2021 | 05.04.2021 | LightningBrothers |
4416 | |
4335 | |
2625 | |
Zeit Dimmer an
Zeit Dimmer aus
Zufällige Pausenzeit
Maximale Helligkeit
4000 | |
