5111 | |
4668 | |
2240 | |
MfG Qasi
1726 | |
2422 | |
2429 | |
2449 | |
2617 | |
2907 | |
External Link
3435 | |
4116 | |
4678 | |
5008 | |
616 | |
820 | |
Gruß Patrick
1597 | |
1646 | |
1671 | |
2002 | |
2763 | |
3974 | |
3710 | |
<blades>
<bladeindex dmxchannel="37">
</bladeindex>
<bladetop dmxchannel="38">
</bladetop>
</bladetopangle>
<bladeleft dmxchannel="40">
</bladeleft>
</bladeleftangle>
<bladebottom dmxchannel="42">
</bladebottom>
</bladebottomangle>
<bladeright dmxchannel="44">
</bladeright>
</bladerightangle>
</blades>
3884 | |
4730 | |
2123 | |
2239 | |
MfG Qasi
2462 | |
H L|H L|H L
B3 |Byte2 |Byte1
2530 | |
2619 | |
2910 | |
3765 | |
4705 | |
RGB+ Kanäle Visualisieren
4805 | |
Zum aufräumen im SpeedMaster
5099 | |
2004 | |
2632 | |
2955 | |
3853 | |
4392 | |
Number; Trigger; Name
0 Go "Flash White Device 1"
2 Go "Flash White Device 2"
4 Go "Flash White Device 3"
6 Go "Flash White Device 4"
8 Go "Flash White Device 5"
10 Go "Flash White Device 6"
12 Go "Flash White Device 7"
XX Go "Flash White Device Y"
4459 | |
4809 | |
4818 | |
4819 | |
4820 | |
4821 | |
S.o.
4822 | |
2430 | |
<zoom dmxchannel="19" >
<rotation dmxchannel="20" >
</rotation>
<index dmxchannel="20" />
</range>
</zoom>
1067 | |
2435 | |
4704 | |
