595 | |
677 | |
- RGB (Beam 1-3)
- Position
- Global
- Position
- Beam 2
- RGB
- Beam 3
- RGB
353 | |
591 | |
593 | |
596 | |
597 | |
599 | |
811 | |
MIDI Timecode
812 | |
MIDI Show Control
1810 | |
1862 | |
| Dimmer
-G12 |
-G1 |
D1 | 0
D2 | 25
-G2 |
D3 | -
D4 | 50
D5 | 75
D3 | 100
SDG = G12, Dimmer At 0 > 100
| Dimmer
-G12 | 0 > 100
-G1 |
D1 | 0
D2 | 33,33
-G2 |
D3 | 66,66
D4 | 100
| Dimmer | Color
-G12 | 0 > 100 |
-G1 | |
D1 | 0 |
D2 | 33,33 |
-G2 | | 0,0,0>255,0,0,0
D3 | 66,66 | 0,0,0
D4 | 100 | 255,0,0
| Dimmer
-G12 |
-G1 | -
D1 | -
D2 | -
-G2 |
D3 | -
D4 | 0
-G1 |
D1 |
D2 | 33,33
D3 | 66,66
D1 | 100
| Dimmer | Color
-G12 | | 0;0;0 > 255;0;0
-G1 | - |
D1 | - | 0;0;0
D2 | - | x;0;0
-G2 | |
D3 | - | y;0;0
D4 | 0 | 255;0;0
-G1 | |
D1 | |
D2 | 33,33 |
D3 | 66,66 |
D1 | 100 |
| Dimmer | Color | Iris
-G12 | | 0;0;0 > 255;0;0 |
-G1 | - | |
D1 | - | 0;0;0 |
D2 | - | x;0;0 |
-G2 | | |
D3 | - | y;0;0 |
D4 | 0 | 255;0;0 |
-G1 | | |
D1 | | | -
D2 | 33,33 | | 1
D3 | 66,66 | |
D1 | 100 | | 2
D4 | | | 0
-G1 | - | |
D1 | - | 0;0;0 |
D2 | - | x;0;0 |
-G2 | | |
D3 | - | y;0;0 |
D4 | 0 | 255;0;0 |
-G1 | | |
D1 | | | -
D2 | 33,33 | | 1
D3 | 66,66 | |
D1 | 100 | | 2
D4 | | | 0
D2 | | | | 0
-G2 | | | |
D1 | | | | 50
D2 | | | | 100
| Dimmer
-G12 | 100
-G1 | 100
D1 | 100
D2 | 100
-G2 | 100
D3 | 100
D4 | 100
(Detail Expanded)
-G12 | | | |
-G1 | - | | |
D1 | - | | |
D2 | - | | |
-G2 | | | |
D3 | - | | |
D4 | 0 | | |
-G1 | | | |
D1 | - | | |
D2 | 33,33 | | |
D3 | 66,66 | | |
D1 | 100 | | |
-G1 | | | |
-D1 | | 0;0;0 | | 0
-D2 | | x;0;0 | | 25
-G2 | | | |
-D3 | | y;0;0 | | 50
-D4 | | 255;0;0 | | 100
-D4, G1, D1 | | | 0 > 100 |
-D4 | | | 0 |
-G1 | | | |
-D1 | | | - |
-D2 | | | 50 |
-D1 | | | 100 |
(Detail, Collapsed)
+D4, G1, D1 | | | 0 > 100 |
(Device view, collapsed)
+D2 | 33,33 | x;0;0 | 50 | 25
+D3 | 66,66 | y;0;0 | | 50
+D4 | 0 | 255;0;0 | 0 | 100
Kommentare?
-D1 | 100 | 0;0;0 | 100 | 0
-D2 | 33,33 | x;0;0 | 50 | 25
-D3 | 66,66 | y;0;0 | | 50
-D4 | 0 | 255;0;0 | 0 | 100
478 | |
Cue 1 | manual | | |
Cue 2 | manual | | |
Cue 3 | follow | 1 | |
Cue 4 | follow | 1 | |
Cue 5 | follow | 1 | |
Cue 7 | manual | | |
479 | |
490 | |
491 | |
492 | |
594 | |
653 | |
725 | |
726 | |
728 | |
1106 | |
1574 | |
1649 | |
1710 | |
1811 | |
1858 | |
1860 | |
1863 | |
1864 | |
2975 | |
