4276 | |
5065 | |
5265 | |
4766 | |
5000 | |
5148 | |
5218 | |
5271 | |
5314 | |
4803 | |
4942 | |
5152 | |
5316 | |
4852 | |
4927 | |
4772 | |
4649 | |
1790 | |
2109 | |
2488 | |
2489 | |
2625 | |
Zeit Dimmer an
Zeit Dimmer aus
Zufällige Pausenzeit
Maximale Helligkeit
2807 | |
2820 | |
Amplitude X und Y
2829 | |
2895 | |
2909 | |
3008 | |
3026 | |
3045 | |
3058 | |
3124 | |
3136 | |
3146 | |
3149 | |
Art des Plugins (Kernel, GUI)
Author
Plugin-Version
kompatible DMXControl-Version
3213 | |
255;128;0 > 0;128;255
0;128;255 > 255;128;0
3262 | |
3264 | |
Block 1, Szene 1
Block 1, Szene 2
Block 1, Szene 3
Block 2, Szene 1
Block 2, Szene 2
Block 3, Szene 1
Block 3, Szene 2
Block 3, Szene 3
Block 3, Szene 4
3296 | |
3302 | |
3308 | |
3309 | |
3336 | |
3360 | |
Create Cuelist
Add Device
Create Cuelist Group
Create Device Group
Create Executor Page
Add Softdesk
Add Power Source
Create Stage View
Create Item List
Import Files
3373 | |
Geprüft mit Build 1602
3413 | |
3463 | |
3526 | |
3533 | |
3538 | |
