5645
DMX PluginWunsch / IdeemittelFeature request: USB CDC / virtual COM port support for...Neu3.3.317.11.202617.11.2026HakanL Aufgabenbeschreibung
Hello,
I’d like to request support in DMXControl 3 for USB DMX interfaces that use the Enttec DMX USB Pro protocol over a standard USB CDC (virtual COM port) connection, instead of an FTDI chipset.
A growing number of adapters work this way. One example is the DMXking ultraDMX MAX, which uses the operating system’s built-in CDC drivers. As far as I can tell, the current Enttec DMX USB Pro plugin only detects FTDI-based devices, so these adapters aren’t found when adding an interface.
Would it be possible to extend the Enttec DMX USB Pro plugin so it can also open a CDC serial / virtual COM port, for example with a manual COM port selection like the Open DMX plugin has? That would make DMXControl 3 work with a wider range of current hardware.
I’m happy to share technical details if that helps.
Thanks for considering this, and for making DMXControl available.
Hakan Lindestaf
DMX Pro Sales
