3554 | |
3629 | |
4447 | |
4260 | |
<rgb>
<red dmxchannel="2" />
<green dmxchannel="3" />
<blue dmxchannel="4" />
<white dmxchannel="5" />
<amber dmxchannel="6" />
<uv dmxchannel="7" />
</rgb>
<amber dmxchannel="72" />
<uv dmxchannel="73" />
</rgb>
</matrix>
2820 | |
Amplitude X und Y
5250 | |
Dauer Programmstart
4479 | |
4891 | |
3853 | |
4673 | |
Name
Macroboard-Profil-Nummer
3734 | |
3309 | |
3028 | |
1864 | |
1695 | |
2149 | |
2997 | |
Vorbereitung:
3096 | |
834 | |
5080 | |
5095 | |
1597 | |
2909 | |
3901 | |
4176 | |
1497 | |
5225 | |
2002 | |
2004 | |
5216 | |
5142 | |
5236 | |
4861 | |
3630 | |
Cuelist Group Number
Executor Number
Executor Page Number
4994 | |
4527 | |
5218 | |
1067 | |
4372 | |
4976 | |
4590 | |
GUI | Wunsch / Idee | niedrig | Device Control merkt sich zuletzt genutztes Farbmodell | Unbestätigt | 3.2.2 | | 25.07.2021 | 25.07.2021 | LightningBrothers |
3569 | |
4336 | |
2430 | |
<zoom dmxchannel="19" >
<rotation dmxchannel="20" >
</rotation>
<index dmxchannel="20" />
</range>
</zoom>
4246 | |
3919 | |
<static>30</static>
</electrical>
4818 | |
4277 | |
3527 | |
3903 | |
