4876 | |
4884 | |
4955 | |
4964 | |
Eingänge
Ausgänge
True / False bzw. 0 / 1
Systemzeit
Parameter
4967 | |
5023 | |
5085 | |
5122 | |
5132 | |
5142 | |
5144 | |
5165 | |
.NET 4.8 found!
ASP.NET Core 6 (x32) found!
ASP.NET Core 6 (x64) found!
XNA 4.0 found!
Windows Installer 3.1 found!
Lade .NET Desktop (x86)...
Lade .NET Desktop (x64)...
Application: Umbra.exe
Architecture: x64
5174 | |
5175 | |
5201 | |
5212 | |
5216 | |
5217 | |
5219 | |
TimecodePlayer | Wunsch / Idee | niedrig | Neue Cue an aktueller Position des Wiedergabemarkers ei... | Unbestätigt | 3.3 Beta x | | 26.12.2023 | 29.12.2023 | LightningBrothers |
5221 | |
5250 | |
Dauer Programmstart
5251 | |
Devices
Device Groups
Cues
Presets
Cuelists
Cuelist Groups
Timecodeshows
5293 | |
Server | Fehlerbericht | niedrig | Kernel beschwert sich, wenn bereits eine DMXC-Instanz i... | Unbestätigt | 3.3 RC x | | 04.04.2024 | 04.04.2024 | LightningBrothers |
5300 | |
280 | |
478 | |
Cue 1 | manual | | |
Cue 2 | manual | | |
Cue 3 | follow | 1 | |
Cue 4 | follow | 1 | |
Cue 5 | follow | 1 | |
Cue 7 | manual | | |
479 | |
491 | |
492 | |
2975 | |
490 | |
614 | |
725 | |
726 | |
728 | |
1067 | |
2435 | |
2670 | |
2765 | |
3731 | |
3741 | |
4081 | |
4083 | |
4099 | |
4704 | |
4823 | |
4860 | |
4969 | |
5002 | |
5095 | |
