3982 | |
2542 | |
3527 | |
4065 | |
s. Screenshot
4088 | |
4269 | |
4896 | |
5048 | |
5089 | |
Gruss Steff
5094 | |
5111 | |
3296 | |
3533 | |
4060 | |
Kernel
GUI
Parametername: prop
Parametername: prop
Parametername: prop
Parametername: prop
4181 | |
3281 | |
in offener Cuelist speichern
in Executor
in Preset
3595 | |
4276 | |
4627 | |
4765 | |
4772 | |
4903 | |
FS#3852
5043 | |
5058 | |
5065 | |
5080 | |
5096 | |
3136 | |
3145 | |
Favoriten für Presets anlegen
3149 | |
Art des Plugins (Kernel, GUI)
Author
Plugin-Version
kompatible DMXControl-Version
3554 | |
3801 | |
3802 | |
3803 | |
3832 | |
4093 | |
4196 | |
4267 | |
4334 | |
1726 | |
2240 | |
MfG Qasi
3146 | |
3190 | |
3226 | |
3302 | |
3360 | |
Create Cuelist
Add Device
Create Cuelist Group
Create Device Group
Create Executor Page
Add Softdesk
Add Power Source
Create Stage View
Create Item List
Import Files
3373 | |
Geprüft mit Build 1602
3607 | |
4268 | |
4340 | |
