3884 | |
5259 | |
5236 | |
4046 | |
4772 | |
3526 | |
5167 | |
Color +++ (erledigt)
ColorTemp (erledigt)
Cool
Dimmer +++ (erledigt)
Effectwheel
Fan –> num. Fann.
Filter
Focus –> num. Fann.
Fog
Frost –> num. Fann.
Gobo +++ (WIP)
Heat
Index –> num. Fann. +/-
Position +++ (erledigt)
PTSpeed –> num. Fann.
Raw –> num. Fann.
Rotation –> num. Fann. +/-
Scale
Shutter +++
Strobe +++
Switch +++ (erledigt)
5265 | |
5285 | |
4849 | |
4678 | |
5249 | |
Issue 1:
Issue 2:
See this video:
2449 | |
3792 | |
4427 | |
4060 | |
Kernel
GUI
Parametername: prop
Parametername: prop
Parametername: prop
Parametername: prop
5287 | |
5211 | |
3557 | |
Danke für Feedback.
4638 | |
5150 | |
Was habe ich gemacht?
4258 | |
5284 | |
5142 | |
4976 | |
4246 | |
3919 | |
<static>30</static>
</electrical>
4293 | |
LG Paul
4291 | |
5286 | |
Soweit so gut.
2422 | |
5065 | |
3888 | |
3956 | |
2019-11-23 15:17:17,158
2019-11-23 15:17:17,171
2019-11-23 15:17:17,185
2019-11-23 15:50:20,200
2019-11-23 15:50:20,222
2019-11-23 15:50:20,245
3296 | |
3966 | |
4380 | |
5165 | |
.NET 4.8 found!
ASP.NET Core 6 (x32) found!
ASP.NET Core 6 (x64) found!
XNA 4.0 found!
Windows Installer 3.1 found!
Lade .NET Desktop (x86)...
Lade .NET Desktop (x64)...
Application: Umbra.exe
Architecture: x64
3409 | |
4592 | |
5247 | |
4775 | |
2488 | |
4623 | |
1574 | |
4910 | |
677 | |
- RGB (Beam 1-3)
- Position
- Global
- Position
- Beam 2
- RGB
- Beam 3
- RGB
5289 | |
5273 | |
4026 | |
