4255 | |
4252 | |
4248 | |
4243 | |
4241 | |
4238 | |
4237 | |
Peer hat ja schon begonnen.
4236 | |
4235 | |
4233 | |
4232 | |
ColorGrid –> Color Grid
4231 | |
4230 | |
Wünsche:
4226 | |
4225 | |
4222 | |
9. Async Ansicht mit Cancel
4208 | |
abbilden und ansprechen.
4207 | |
<prism dmxchannel="0">
</prismrotation>
</prism>
<prism dmxchannel="2">
</prismrotation>
</prism>
4205 | |
4202 | |
4196 | |
4190 | |
4188 | |
4180 | |
4175 | |
4174 | |
4173 | |
4171 | |
4167 | |
4162 | |
4156 | |
4152 | |
Cuelists
Cuelist Groups
Devices
Device Groups
Group Number (Group Master)
(Executor
Executor Pages)
Electricity
4151 | |
4150 | |
4142 | |
4141 | |
4133 | |
4122 | |
4118 | |
4117 | |
4116 | |
4112 | |
4110 | |
4101 | |
4099 | |
4098 | |
Meine Vorschläge dazu:
4093 | |
4084 | |
4083 | |
4081 | |
