IDProgressCategoryTask TypeSeverity  descSummaryStatusReported InDue In VersionOpenedLast EditedOpened by
5516
GUI & ServerFehlerberichtCriticalDMXC3.3.0 crash (transport connections?)Neu3.3.106.10.202506.10.2025philbearman Task Description
Error Description
While I was running a show DMXC3.3 became unresponsive - the Umbra window was filled with a repeating warning which I think related to “transport connections”. I have attached the log files.
The GUI became blank (I wasn’t able to access the project manager, cuelists etc). The cue that was playing (”040 Charles and Cat”) continued to play - chases continued to run.
Unfortunately, under the pressure of a live show I didn’t think to take a screenshot. I had to close DMXC and restart the software in order to continue with the show.
Looking at the log file, I believe the error happened at around 19:53 on 4th October. (Lumos.log.2)
The only unusual circumstance was that I noticed shortly after I started the show that my laptop was connected to both a wifi network and a wired router, so I disabled the wifi after that. But the crash didn’t occur immediately after that.
If the crash was due to the configuration of my laptop/network I would like to know so I can avoid this happening again in the future :-)
Notes
DMXC V3.3.0.1027 on Windows 10.
5352
GUI & ServerFehlerberichtCriticalRandom Crashing 3.2.3 | Zufällige Abstürze 3.2.3Neu3.2.324.06.202424.06.2024shween Task Description
This Task is to bring attention to the occurrences of random crashing experienced when programming the last project worked on. (v3.2.3)
I cannot pinpoint exactly what causes these issues but I have attached a LOG Export from the project. I hope it is not too late since the bugs occurred to export the LOG.
These crashes ranged anywhere from:
-Cue lists randomly not tracking correctly after some time programming inside the GUI.
-Tracking True / False Not applying to cue lists.
-Fixture Parameters not being able to be selected in the GUI or Programmer.
-Rare, but the whole GUI would sometimes lock up to the point I could not save a project before attempting to restart.
Generally, a full restart of the DMXControl Application would resolve the issues.
Sometimes, a full system restart was required.
Also, it seems the parameter: “Reset When Released” has absolutely no effect on Cue list release behavior.
I did notice this trend: that often when using Fanning Parameters (E.g. -90<>90 … 0>120>0 … 0<>90) in X/Y Moving head parameters, that DMXControl 3.2.3 would then behave extremely erratically, and eventually begin adding its own values in parameter fields, and eventually crash. When closing the application, I would then be presented with a messaged saying: “DMXControl Crashed - This should not have happened. Please Export Log to Bugtracker.”
Dedicated Show and Cue List playback seems extremely stable, it is only in heavy periods of programming that these crashes seem to occur.
Thank You.
Diese Aufgabe soll auf das Auftreten von zufälligen Abstürzen aufmerksam machen, die beim Programmieren des zuletzt bearbeiteten Projekts aufgetreten sind. (v3.2.3)
Ich kann nicht genau sagen, was diese Probleme verursacht, aber ich habe einen LOG-Export aus dem Projekt angehängt. Ich hoffe, es ist nicht zu spät, da die Fehler beim Exportieren des LOG aufgetreten sind.
Diese Abstürze reichten von:
-Cue-Listen werden nach einiger Zeit in der GUI zufällig nicht korrekt verfolgt.
-Tracking True / False Gilt nicht für Cue-Listen.
-Geräteparameter können nicht in der GUI oder im Programmierer ausgewählt werden.
-Selten, aber die gesamte GUI wurde manchmal bis zu dem Punkt gesperrt, an dem ich ein Projekt nicht speichern konnte, bevor ich versuchte, neu zu starten.
Im Allgemeinen würde ein vollständiger Neustart der DMXControl-Anwendung die Probleme beheben.
Manchmal war ein vollständiger Systemneustart erforderlich.
Außerdem scheint der Parameter: “Reset When Released” absolut keinen Einfluss auf das Freigabeverhalten der Cue-Liste zu haben.
Ich habe diesen Trend bemerkt: dass oft bei der Verwendung von Fanning-Parametern (z. B. -90<>90 … 0>120>0 … 0<>90) in X/Y-Moving-Head-Parametern, dass sich DMXControl 3.2.3 dann extrem unberechenbar verhält und schließlich anfängt, seine eigenen Werte in Parameterfeldern hinzuzufügen und schließlich abstürzt. Beim Schließen der Anwendung wurde mir dann eine Meldung angezeigt, die besagt: “DMXControl abgestürzt - Dies hätte nicht passieren dürfen. Bitte exportieren Sie das Protokoll in den Bugtracker.”
Die dedizierte Show- und Cue-List-Wiedergabe scheint extrem stabil zu sein, nur in schweren Programmphasen scheinen diese Abstürze aufzutreten.
Vielen Dank.
5236
GUI & ServerFehlerberichtCriticalDMXC 3.3 RC1 öffnet nach GUI-Crash (IA) vorhandenes Pro...Neu3.3 RC x02.01.202405.08.2024djquickwilli Task Description
Ich habe ein altes 3.2.3 Projekt importiert und weiter bearbeitet.
Während eines Klicks im Input-Assignment (evtl. auf den Reiter oben) verschwand das IA und ließ sich nicht mehr aus dem Menü heraus aktivieren.
Programm beendet und versucht, Projekt wieder zu laden führte zum “Unable to load the Project due to an exeption”. Das gilt für alle Unterversionen und auch für ein exportiertes und neu geöffnetes Projekt.
IA-Fenster konnte durch “Reset Windows Layout” wieder dargestellt werden.
02:03:15 WARN  ProjectManager - Error when loading Project 2024_330_V001_Basisprojekt: Der Vorgang wurde erfolgreich beendet.
System.ComponentModel.Win32Exception (0x80004005): Der Vorgang wurde erfolgreich beendet.
   at org.dmxc.lumos.Kernel.Master.MasterManager.org.dmxc.lumos.Kernel.Run.ILumosProjectManager.loadProject(LumosIOContext context, ELoadTime time) in D:\Jenkins\workspace\Lumos_Pipeline_3.3\Lumos\src\Kernel\Master\MasterManager.cs:line 747   at org.dmxc.lumos.Kernel.Project.ProjectManager.<>c__DisplayClass51_1.<LoadProjectFromStream>b__1(ILumosManager m) in D:\Jenkins\workspace\Lumos_Pipeline_3.3\Lumos\src\Kernel\Project\ProjectManager.cs:line 426
5554
TimecodePlayerFehlerberichtHighMehrfaches Starten und Pausieren einer Timecodeshow sor...Neu3.3.116.02.202620.02.2026leunam Task Description
Neues Projekt erstellt
Vier RGB Devices hinzufügt
Eine Cuelist mit einem Eintrag, die Helligkeit und Farbe der vier Geräte setzt.
Neue Timecodeshow hinzugefügt, die alle zwei Sekunden die Cue List insgesamt vier mal aufruft.
Nun die Timecodeshow starten und wieder anhalten und dies wiederholen - die Timecode Show nicht zuende laufen lassen.
Cursor wieder an den Anfang und dann wiederholen.
Spätestens nach zwei Durchläufen bleibt der Cursor zu Beginn einer Cuelist kurz stehen und zittert.
In einer größeren TimecodeShow war dann Ton und Licht verzögert und es kam vor, dass der Cursor nach dem Starten irgendwo hin gesprungen ist oder sich gar
nicht mehr vesetzen lässt.
Ein Neustart von DMX löst dann das Problem für ca. 3x Pausieren, dann muss wieder neu gestartet werden.
Kein “Zittern” des Cursors und zuverlässiges Starten der Timecode Show ohne Zeitsprünge
Version 3.3.1.1136
20:56:12 INFO  Timecode - Stopped: [1, New TimecodeShow]
20:56:13 ERROR Timecode -
org.dmxc.lumos.Kernel.Exceptions.AlreadyRegisteredException: Timeslot for ID 12b9c255-1f9f-4a2a-84f5-b9822edec50a-TS already registered
   at org.dmxc.lumos.Kernel.Time.TimeManager.registerFixedTimeSlot(String targetId, ITimeSlot timeSlot) in D:\Jenkins\workspace\Lumos_Pipeline_3.3\Lumos\src\Kernel\Time\TimeManager.cs:line 89
   at org.dmxc.lumos.Kernel.Timecode.Timecode.Play() in D:\Jenkins\workspace\Lumos_Pipeline_3.3\Lumos\src\Kernel\Timecode\Timecode.cs:line 919
20:56:13 INFO  Timecode - Run:     [1, New TimecodeShow]
20:56:13 INFO  Timecode - Start:   [1, New TimecodeShow] Frame:     0
20:56:15 WARN  Timecode - Performing the Frame: 39 takes too much time, it exceeds the max. frame duration 191.4261ms >= 40ms
20:56:19 WARN  Timecode - Performing the Frame: 139 takes too much time, it exceeds the max. frame duration 169.6493ms >= 40ms
20:56:24 WARN  Timecode - Performing the Frame: 263 takes too much time, it exceeds the max. frame duration 155.5815ms >= 40ms
20:56:26 INFO  Timecode - Break:   [1, New TimecodeShow] Frame:   319 Time: 00:00:12.7770985
20:56:41 INFO  Timecode - Stop:    [1, New TimecodeShow] Frame:   319 Time: 00:00:13.5876047
20:56:41 INFO  Timecode - Stopped: [1, New TimecodeShow]
20:56:43 ERROR Timecode -
20:56:43 INFO  Timecode - Run:     [1, New TimecodeShow]
20:56:43 INFO  Timecode - Start:   [1, New TimecodeShow] Frame:     0
20:56:44 WARN  Timecode - Performing the Frame: 39 takes too much time, it exceeds the max. frame duration 202.5471ms >= 40ms
20:56:48 WARN  Timecode - Performing the Frame: 139 takes too much time, it exceeds the max. frame duration 183.8875ms >= 40ms
20:56:49 INFO  Timecode - Break:   [1, New TimecodeShow] Frame:   182 Time: 00:00:07.2996301
20:56:50 INFO  Timecode - Resume:  [1, New TimecodeShow]
20:56:53 WARN  Timecode - Performing the Frame: 264 takes too much time, it exceeds the max. frame duration 195.172ms >= 40ms
20:56:56 INFO  Timecode - Break:   [1, New TimecodeShow] Frame:   335 Time: 00:00:13.3854502
20:56:58 INFO  Timecode - Stop:    [1, New TimecodeShow] Frame:   335 Time: 00:00:13.5248318
20:56:58 INFO  Timecode - Stopped: [1, New TimecodeShow]
20:56:59 ERROR Timecode -
20:56:59 INFO  Timecode - Run:     [1, New TimecodeShow]
20:56:59 INFO  Timecode - Start:   [1, New TimecodeShow] Frame:     0
20:57:00 WARN  Timecode - Performing the Frame: 39 takes too much time, it exceeds the max. frame duration 158.7684ms >= 40ms
20:57:04 WARN  Timecode - Performing the Frame: 139 takes too much time, it exceeds the max. frame duration 179.8303ms >= 40ms
20:57:07 INFO  Timecode - Break:   [1, New TimecodeShow] Frame:   236 Time: 00:00:09.4463131
20:57:08 INFO  Timecode - Resume:  [1, New TimecodeShow]
20:57:09 WARN  Timecode - Performing the Frame: 264 takes too much time, it exceeds the max. frame duration 165.9721ms >= 40ms
20:57:12 INFO  Timecode - Break:   [1, New TimecodeShow] Frame:   328 Time: 00:00:13.1409705
20:57:13 INFO  Timecode - Stop:    [1, New TimecodeShow] Frame:   328 Time: 00:00:19.0884693
20:57:13 INFO  Timecode - Stopped: [1, New TimecodeShow]
20:57:15 ERROR Timecode -
20:57:15 INFO  Timecode - Run:     [1, New TimecodeShow]
20:57:15 INFO  Timecode - Start:   [1, New TimecodeShow] Frame:     0
20:57:15 WARN  Timecode - Performing the Frame: 39 takes too much time, it exceeds the max. frame duration 188.1449ms >= 40ms
20:57:19 WARN  Timecode - Performing the Frame: 139 takes too much time, it exceeds the max. frame duration 165.4547ms >= 40ms
20:57:24 WARN  Timecode - Performing the Frame: 264 takes too much time, it exceeds the max. frame duration 177.6584ms >= 40ms
20:57:26 INFO  Timecode - Break:   [1, New TimecodeShow] Frame:   298 Time: 00:00:11.9164152
20:57:27 INFO  Timecode - Stop:    [1, New TimecodeShow] Frame:   298 Time: 00:00:17.0859307
20:57:27 INFO  Timecode - Stopped: [1, New TimecodeShow]
20:57:29 ERROR Timecode -
usw…
5497
GUI & ServerFehlerberichtHighDMX-ausgabe, obwohl Programmer leer, keine Cues mehr am...Neu3.3.007.08.202508.08.2025Companion Task Description
Ich habe den Programmer geleert, alle Cues gestoppt und den Blackout betätigt. Meine Scheinwerfer leuchten weiterhin rot
Laut Channel Overview wird weiterhin DMX ausgegeben.
Es lassen sich auch keine Szenen mehr umschalten, andere Farben oder Befehle ausgeben - die DMX-Ausgabe scheint eingefroren zu sein.
Licht aus
Ich nutze ein DMX4ALL-USB-Interface USB-DMX Stage-Profi MK3 V2
Nach dem Schließen des Projektes werden laut Channel Overview kein DMX mehr ausgegeben, die Scheinwerfer leuchten weiterhin rot.
Das Beenden Des Programmes hat nicht einwandfrei funktioniert (siehe screenshot).
Nach dem Enter drücken kamen noch ein paar Zeilen, aber das Fenster hat sich geschlossen, so dass ich keinen Screenshot mehr machen konnte.
Auch das komplette beenden von DMXControl hat die Beleuchtung nicht deaktivert. Vielleicht liegt es auch am Interface.
Oder an Windows. Kann man in den Logs was erkennen?
5481
GUI & ServerFehlerberichtHighPerformanceprobleme mit GroupmasternNeu3.3.1 Beta x15.07.202515.07.2025Phil2811 Task Description
Ich habe ein Projekt mit 50 Groupmastern. Wenn ich einen Master von 0 nach 100% schiebe, bleibt dieser mehrfach kurz hängen.
Dieses Verhalten beobachte ich sowohl im Master Fenster als auch im Softdesk und im Input Assignement.
In der Visualisierung in 3D View als auch mit realen Geräten wird jedoch dynamisch ohne ruckeln gedimmt. Daraus folgere ich, dass die DMX-Werte ohne Verzögerung/Hängenbleiben weitergegeben werden.
Ich habe nun bei einigen Groupmastern die Eigenschaft deaktiviert, dass ein Master erstellt wird. Nun habe ich nur noch 10 Groupfader. Das Verhalten ist besser geworden, aber keines Falls zufrieden stellend!
Ich erwarte, dass sich die Groupmaster flüssig bewegen
Version: 3.3.1 Beta 42
Projekt und Logs sind angefügt.
5435
GUI & ServerFehlerberichtHighDDF Angle Offset Has No Effect on RADIXNeu3.3.014.03.202514.03.2025shween Task Description
Hello!
I wanted to add a point on DDF RADIX DDF Profiles.
It seems that the <angleoffset> parameter has no effect on changing the orientation of pixel start points, or, in the visual GUI.
I have no idea if this was ever working in previous versions, as I have only started using RADIX Recently. Here is a Demo DDF for a fixture I am trying to make it wori with, but, also trying to make DDF for custom layouts and saving it as a full fixture for efficient processing of many ‘dimmers’
For instance. If pixel one starts at the 3:00 position, and I set ‘angle offset’ to 90 clockwise, the GUI, and actual DMX Fixture have no effect. the First pixel is stuck at default position in DMXC.
I am not sure I I am doing something wrong, But I also tested in other strange ways. Nothing seemed to work.
Thank you!
5430
GUI & ServerFehlerberichtHighSoftdesk schließt sich während ShowNeu3.3.023.02.202524.02.2025 Task Description
Während einer Show gestern Abend ist mein Softdesk abgestürzt bzw. hat sich geschlossen. Beim erneuten öffnen waren die Cuelist Monitore leer und es ließ sich nichts mehr anklicken. Das Softdesk Fenster konnte auch nicht mehr geschlossen werden. Kurz vorher haben schon die zwei abgedockten Fenster geflackert und sich neu aufgebaut.
Projekt:
  • Projekt erstellt in 3.2.3
  • Projekt importiert in 3.3 RC5
  • Projekt weiter verwendet in 3.3
Offene Fenster (Laptopmonitor + externer Monitor):
  • DMXControl auf externem Monitor
  • Executer-Fenster abgedockt auf externem Monitor
  • “New Softdesk”-Fenster abgedockt auf Laptopmonitor
    • im Projekt gibt es noch das “Main Softdesk” welches noch in 3.2.3 erstellt wurde. Das “New Softdesk” wurde unter 3.3 RC5 erstellt.
Hardware:
  • Lenovo Thinkpad T580
  • i7-8650U
  • NVIDIA GeForce MX150
    • “DMXControl 3 GUI” ist auf “Hohe Leistung” gestellt und der Haken bei “Keine Optimierung für Fensterspiele verwenden” ist gesetzt.
  • 16 GB RAM 2400 MHz Single Channel
  • beide Monitore 1080p
  • Midi Pult APC Mini
    • Verwendet um Executer steuern, einzelne Cuelists direkt anzusteuern und Tab und Sync vom Speedmaster 1 zu steuern.
Keine Abstürze. Ohne das Midi Pult hätte ich keine Möglichkeit mehr gehabt das Licht zusteuern.
Weiteres
Ich möchte noch sagen, dass ich DMXControl als gutes Projekt sehe und denke, dass die 3.3 ein wichtiger Schritt in die richtige Richtung ist. Leider finde ich die Arbeitsweise teileweise zu umständlich, gerade wenn man nicht viel Zeit hat eine Show zu programmieren. Ich komme vom grandMA (pico und ultra light). Wenn ich dort eine neue Szene in einer neuen Cuelist speichern will muss ich einfach nur auf “Store” drücken und dann auf eine Taste eines Executors. Ist der Executor schon belegt wird gefragt ob ich eine zweite Cue hinzufügen möchte oder eine neue Cuelist anlegen will. Ich denke das würde sich auch gut in DMXC3 umsetzen lassen. Button Executor wären denke ich auch eine gute Ergänzung um einfache Cuelists zu starten und zu stoppen.
Bei weiteren Fragen könnt ihr euch gerne per E-Mail melden. Ich helfe gern dieses Projekt nach vorne zu bringen.
5429
GUI & ServerFehlerberichtHigh'Pixel Random' Breaks Random Pixel Matrix Effect Genera...Neu3.3.022.02.202522.02.2025shween Task Description
When using the Matrix Effect: ‘Random’, Changing the value of the ‘Pixel Random’ parameter breaks the effect.
5428
GUI & ServerWunsch / IdeeHighAnimated Bitmap SupportNeu3.3.022.02.202522.02.2025shween Task Description
It would be great if the Bitmap Matrix Effect supported animated files including WEBM, GIF, Various Video Files, Live Video Input ETC.
5427
GUI & ServerFehlerberichtHighBitmap Pixel Effect does not recall image from cueNeu3.3.022.02.202522.02.2025shween Task Description
Bitmap Pixel Effect does not recall image from cue.
When saving a bitmap pixel effect to a cue, only the default DMXC Logo appears when recalling the cue. The cue does not recall the Bitmap Source image.
5387
GUI & ServerFehlerberichtHighPerformance Probleme bei vielen (größeren) CuelistsNeu3.3 RC x08.09.202421.05.2025Skyfalko Task Description
Forum: https://forum.dmxcontrol-projects.org/index.php?thread/17686-performance-probleme-bei-vielen-cuelists/
Hallo zusammen,
wir verwenden bei uns Szenenlisten, um Lichtstimmungen passend zu einem Lied vor zu programmieren.
Dabei erstellen wir pro Lied eine neue Szenenliste und fügen dieser andere Szenenlisten, wie Beispielsweise einen Bewegungseffekt, Dimmereffekt oder Farbe hinzu um diese mit der Lied- Szenenliste zu starten.
Die Lied- Szenenliste hat dabei nur den Auftrag alle anderen zu starten (erste Cue (andere Szenenliste) auf Manual und dann alle folgenden mit follow 0ms danach), sodass wir dann nur noch die einzelnen Cuelists mit Mastern in ihrer Intensität und Schnelligkeit reinmischen müssen.
Da bei uns regelmäßig unterschiedliche Bands auftreten, kommen da schnell ein paar Lied- Szenenlisten zusammen.
Nun das Problem:
Mir ist aufgefallen, dass nach ca. 120 Lied- Szenenlisten mein Projekt deutlich langsamer läuft.
So fällt bsp. bei Strobe- Effekten auf, die per Tastatur mit “GO” gestartet werden und beim Loslassen der Taste über Binary Switcher über “STOP” gestoppt werden sollen, nicht mehr gestoppt werden und es einem zweiten oder auch dritten Drücken auf die Taste bedarf bis die Cuelists gestoppt wird.
Auch haben unsere Slider, die die Groupmaster steuern ein deutliches Delay (teilweise ca. 3 Sekunden)
Um das Projekt im Live-Betrieb bedienbarer zu machen, löschen wir vor jedem Konzert alle nicht verwendeten Lied-Cuelists raus. Dies hat einen deutlichen Einfluss auf die Performance.
Aktuell sind wir auf der 3.3.0 RC3 auf einem Laptop mit aktuellem AMD Ryzen 5 und 8GB Ram.
Auf der RC2 und einem anderen Rechner mit i7 und 16GB Ram hatten wir aber auch das selbe Problem.
Vielen Dank
Falko
5366
GUIFehlerberichtHighBeam setting WindowNeu3.3 RC x28.07.202401.08.2024wide Task Description
Dragging the slider bar with the mouse on the beam window’s focus or other slider bar causes it to pull and tremble.
3.3RC3
5285
GUI & ServerFehlerberichtHighParameterMaster können bei Frequency von Positionseffek...Neu3.3 RC x23.03.202405.08.2024IlluminateXperience Task Description
Das angehängte Projekt zu exportieren war erst nach Hilfe von JPK möglich (siehe  FS#5284  - Export von Projekten unmöglich).
Version: 3.3.0 RC 2
5167
GUIToDoHighVorschläge für Visualisierung der PropertiesZugeteilt3.3 Beta x3.417.10.202321.12.2023JPK Task Description
  • Color +++ (erledigt)
  • ColorTemp (erledigt)
  • Cool
  • Dimmer +++ (erledigt)
  • Effectwheel
  • Fan –> num. Fann.
  • Filter
  • Focus –> num. Fann.
  • Fog
  • Frost –> num. Fann.
  • Gobo +++ (WIP)
  • Heat
  • Index –> num. Fann. +/-
  • Position +++ (erledigt)
  • PTSpeed –> num. Fann.
  • Raw –> num. Fann.
  • Rotation –> num. Fann. +/-
  • Scale
  • Shutter +++
  • Strobe +++
  • Switch +++ (erledigt)
Anmerkungen
5142
GUI & ServerFehlerberichtHighDMXC-Komplettabsturz inkl. Main Runnable stuck beim Kop...Unbestätigt3.3 Beta x06.09.202326.09.2023StefanKrupop Task Description
Beim Bearbeiten einer Szenenliste hatte ich zwei Einträge (Strophe / Refrain) in die Zwischenablage kopiert, um sie mehrfach einzufügen. Das hatte ich in der Vergangenheit auch schon mal ohne Probleme getan. Dieses Mal (natürlich wenn man in Eile ist…) ist dabei aber DMXC ziemlich komplett abgeschmiert, auch der Kernel war nicht mehr zu gebrauchen.
Im Kernel-Log findet sich auch die Zeile
Das ganze passiert so etwa um 18:09.
Im Projekt gab es hinterher auch eine Version 0.0.122, die aber scheinbar nur in den Metadaten existiert, aber nicht auf Disk geschrieben wurde. Daher habe ich die 121 angehängt. Gearbeitet hatte ich in der Szenenliste “Sturm auf die Hausi”.
Passiert in 3.3 Beta 9 (Komma 1, JPK hatte die Anzeige der Presets noch gefixt).
4678
TimecodePlayerToDoHighTimecodePlayer ScrollZomView überarbeiten, fixen ersetz...Zugeteiltunbestimmt3.430.12.202108.11.2024Qasi Task Description
4638
GUI & ServerFehlerberichtHighLeere Device Group löscht gespeicherte EigenschaftenNeu3.2.225.10.202124.11.2021MisterX Task Description
Device Group mit Generic RGB, Farbe auf Rot in Cuelist speichern. → funktioniert wie erwartet
Anschließend alle Devices aus der Gruppe löschen, Projekt speichern und neu laden.
Projekt neu laden, wieder Geräte in die Gruppe hinzufügen, Cuelist starten → keine Farbe mehr vorhanden, bei “Edit in Programmer” wird keine Eigenschaft aufgerufen, der Programmer bleibt leer.
Hintergund:
Ich habe für mich ein Standard-Projekt erstellt, dieses hat 4 Gruppen und je nach Veranstaltung werden andere Geräte in die Gruppen aufgeteilt, teils mit vollkommen unterschiedlichen Setups. Mir ist es nun schon passiert das ich mir beim Anpassen des Projektes alles zerstört habe weil ich erst einmal alle Gruppen geleert haben.
Beim letzten Mal wollte ich das ganze verhindern und habe ein Gerät in die Gruppe gesteckt das ich sonst nicht nutze, leider tritt der Fehler auch auf wenn das Gerät keine Farbeigenschaft hatte, daher hat mir die Nebelmaschine in der Gruppe auch nicht vor dem Verlust geschützt.
4427
SoftdeskFehlerberichtHighSoftdesk wird beim Schließen der GUI nicht gespeichertUnbestätigt3.2.229.03.202106.04.2025LightningBrothers Task Description
4293
SoftdeskFehlerberichtHighButtons verschwindenZugeteilt3.2.119.11.202028.12.2020 Task Description
LG Paul
4291
InputAssignmentWunsch / IdeeHighBild des Graphen automatisch erstellen lassenUnbestätigt3.2.130.10.202025.12.2020JPK Task Description
4258
InputAssignmentFehlerberichtHighFehlerhafte Wertevalidierung lässt GUI einfrierenNicht Reproduzierbar3.2.2 Beta x01.09.202016.03.2021Mic Task Description
4246
ServerFehlerberichtHighDDF führt zu Exception im Raw-BereichAuf User warten3.2.111.08.202025.08.2022JPK Task Description
3888
SoftdeskFehlerberichtHighÄnderungen an Softdesks werden nicht an andere Sessions...Neu3.23.422.10.201928.11.2021Mic Task Description
3792
SoftdeskWunsch / IdeeHighSoftdeskschnittstelle für custom ControlsZugeteilt3.2 Beta x3.412.09.201931.10.2023Mic Task Description
3557
DMX PluginFehlerberichtHighNach wenigen Sekunden Betrieb keine DMX Befehle mehr au...Neu3.1.320.04.201922.04.2019 Task Description
Danke für Feedback.
3526
StageViewToDoHighWARN org.dmxc.lumos.XNAViews.GraphicsDeviceControl - F...Zugeteilt3.2 Beta x3.431.03.201926.11.2021LightningBrothers Task Description
2449
ServerToDoHighTests für Autoprepare schreiben!Zugeteilt3.0TBD (UIS)13.04.201601.08.2025Qasi Task Description
2422
ServerFehlerberichtHighAutoprepare funktioniert in bestimmten konstilationen n...Zugeteilt3.0TBD (UIS)07.03.201601.08.2025Qasi Task Description
Funktioniert nicht bei:
Funktioniert bei:
P.S.
5575
SoftdeskFehlerberichtMediumSoftdesk: Cuelist Monitor Neu3.3.2 Alpha/Beta x12.05.202612.05.2026x.Chris.x Task Description
1. Der “Hintergrund” vom Cuelist Monitor ist schwarz statt grau, wenn das gesamte Cuelist Fenster nicht von Cues ausgefüllt wird
2. Die Cuelist Monitore können nicht mehr einfach per Linksklick angewählt werden. Mittlere oder rechte Maustaste ist notwendig
3. Der Inhalt der Cuelist Monitore verschwindet manchmal (Cuelist Monitor komplett leer) und kann nur durch neuanlage wieder hergestellt werden (ist auch bei 3.2.3 manchmal passiert)
1. Grauer Hintergrund
2. Normal anwählbar wie alle anderen Elemente (Buttons, Slider etc.)
3. Das die Cuelist Monitore stabil gefüllt bleiben
5561
GUI & ServerFehlerberichtMediumSpecial cues not being tracked correctly with "Go To" f...Neu3.3.127.03.202627.03.2026philbearman Task Description
I’ve noticed a cuelist behaviour that seems incorrect
I have a cuelist (we’ll call this the master cuelist), and within that cuelist, I am triggering some other cuelists (we’ll call these sub-cuelists) using the ‘Go’ and ‘Stop’ special cues.
If I use the ‘Go to’ function to jump to a later point in the master cuelist after I have triggered a ‘go’ and then a ‘stop’ on a sub-cuelist, that sub-cuelist remains playing when I believe it should be stopped.
So in the attached example screenshot, if I “Go To” cue 17, I would expect the ‘Petro Alts’ and ‘Petro Zips’ cuelists to be stopped, but instead they are running.
If I play the cuelist from the start, they behave as expected.
5500
InstallerFehlerberichtMediumInstaller bemerkt Fehlen von Microsoft.NETCore.App Vers...Unbestätigt3.3.131.08.202516.09.2025StefanKrupop Task Description
Nach der Installation des DMXC 3.3.1-Release lies sich auf einem Windows 10-Notebook der Kernel nicht starten. GUI und Umbra liefen.
Das Kernel-Fenster zeigte nur die folgende Fehlermeldung:
It was not possible to find any compatible framework version
The framework 'Microsoft.NETCore.App', version '6.0.0' was not found.
  - The following frameworks were found:
      3.1.32 at [C:\Program Files (x86)\dotnet\shared\Microsoft.NETCore.App]
      5.0.17 at [C:\Program Files (x86)\dotnet\shared\Microsoft.NETCore.App]
You can resolve the problem by installing the specified framework and/or SDK.
The specified framework can be found at:
  - https://aka.ms/dotnet-core-applaunch?framework=Microsoft.NETCore.App&framework_version=6.0.0&arch=x86&rid=win10-x86
Nach der Installation des Frameworks aus dem Link in der Meldung funktionierte auch der Kernel.
5467
ServerFehlerberichtMediumKernel hängt sich auf, wenn die Netzwerkkonfiguration g...Neu3.3.004.06.202504.06.2025 Task Description
Wird die Netzwerkkonfiguration geändert, zum Beispiel wird die Statische IP/Subnetzmaske geändert, hängt der Kernel sich auf.
Discord: bastelpichi
5436
GUIFehlerberichtMediumEinstellung für Project Autosave fehlenAuf User warten3.3.03.3.x26.03.202501.11.2025LightningBrothers Task Description
  • Keep files per project
  • Maximum MB per project
  • Warning MB in project store
    </TreeItem>
    </TreeItem>
    </TreeItem>
    </TreeItem>
    </TreeItem>
    </TreeItem>
5411
InputAssignmentFehlerberichtMediumbeim entfernen einer Node werden alle "gleichen" Nodes ...Auf User warten3.3 RC x12.01.202513.01.2025EDER Task Description
Ich verwende den RC5 der 3.3
5405
UmbraFehlerberichtMediumFATAL DMX Control 3 UmbraNeu3.3 RC x15.12.202414.10.2025 Task Description
Normaler Programmstart.
3.3.0 RC5
Nichts dergleichen gefunden im Bugtracker.
EDIT JPK: E-Mail-Adresse entfernt, da bereits an anderer Stelle vorhande
Nicht relevant für fehler.
5389
PluginFehlerberichtMediumDMXC3.X.X Soundlight USBDMX-one funktioniert nichtNeu3.3 RC x10.09.202414.10.2025GewinnerComic49 Task Description
Das Soundlight USBDMX-one Interface funktioniert seit zumindest (getestet) V3.2.3 nicht. Ich habe seither eine .ddl verwendet die ich bekommen habe, die das gefixt hat. Diese ist als Anhang zugefügt. Ich denk nicht, dass die logs nichts bringen, sonst wäre das schon aufgefallen… Edit: Log für V3.3.0RC3 ohne susbdmx.ddl angefügt. Das mit einer größe von 110.1Kb ist das richtige. ich kann das andere nicht löschen.
Reproduktion:
1. Dmxc 3.x.x (getestet von 3.2.3 bis 3.3.0 RC3) installieren und Plugin im Installer aktivieren (Interface ausgewählt.png)
2. Soundlight USBDMX-one einstecken (lul hab ich einmal vergessen……)
3. Das Interface wird bei den Interfaces nicht erkannt (Interface wird in dmxc nicht erkannt.png)
1. Im Installationspfad unter Kernel/Plugin die Angehängte .ddl einfügen (susbdmx.ddl hinzugefügt.png)
2. DMXC Neustarten
3. Interface wird erkannt und funktioniert (Interface wird in DMXC erkannt.png)
5386
GUI & ServerFehlerberichtMediumMatrix Ausgabe bleibt stehen sobalt Man eine Farbe ausg...Neu3.3 Beta x05.09.202408.03.2026steff Task Description
Matrix Ausgabe bleibt stehen sobalt Man eine Farbe ausgewäht hat
Ich habe 150 WS2812 Pixel angelegt und diese habe ich dann als Matrix (15×10) angelegt.
Wenn ich jetzt einen Matrix Effekt auf die Matrix ziehe und den Dimmer auf 100 einstelle.
Es wird in der Stage View auf den einzelnen Pixeln sowie auf der Matrix das entsprechende angezeigt.
Wähle ich unten nun unter Color im Farb-Steuerungsfenster eine Farbe aus wird auch diese angezeigt.
Auch wenn ich die Farbe wieder auf schwarz stelle bleibt die Anzeige auf den einzelnen Pixel sowie auch die Ausgabe stehen.
Die Anzeige der Matrix in der Stage View läuft weiter.
Ich habe das mal in einem Video zur besseren Veranschaulichung aufgenommen und hier angehängt.
Auch mein Projekt Beispielprojekt ist angehängt.
Ich zeige das im Video in der 3.3.0 RC3, es ist aber auch in der 3.2.3 schon so.
Ich würde erwarten deas die Anzeige in der Stage View sowie die Ausgabe wie im Matrix Fenster zu sehen ist weiterläuft.
5331
GUI & ServerFehlerberichtMediumBühnenansicht, Scheinwerfer, Fanning und Handlung insta...Neu3.2.317.05.202414.08.2024 Task Description
5311
TimecodePlayerFehlerberichtMediumTimecode wird bei Wiedergabestart in der Show nicht meh...Unbestätigt3.3 RC x28.04.202408.11.2024LightningBrothers Task Description
5289
Project ExplorerFehlerberichtMediumSpeedmaster: Es lassen sich nur eine begrenzte Anzahl S...Neu3.3 RC x29.03.202409.11.2024MisterX Task Description
Es lassen sich nur ca 16-17 Speedmaster anlegen.
Im bestehenden Projekt konnte ich 17 Speedmaster anlegen, in einem leeren Projekt nur 16, anschließend Fehlermeldung im Kernel.
Anbei die Logs erzeugt nach dem Versuch mit leerem Projekt.
5273
SoftdeskFehlerberichtMediumSoftdesk Werte für Position und Größe werden nicht sofo...Benötigt Tests3.2.33.3.x10.03.202401.08.2025steff Task Description
5258
GUI & ServerFehlerberichtMediumChaser filter restart with previous stateAuf User warten3.3 RC x12.02.202422.10.2024 Task Description
Error Description
Expected behavior
Notes
Process:
* add some generic fixture with dimmer only,
* create a group for those fixtures,
* assign a chaser to the dimmer property of the group device: fixtures light on from the first to the last,
* create a cue from this state,
* clear programmer,
* set the fade of the created to 0,
* set the release time of the cuelist to 0,
* when pressing the GO button, chaser starts from the first fixture,
* press STOP when another fixture than the first is on, for example, the third,
* press GO: for a short time, the third fixture is on (and it’s visible too with the Channel Overview) and immediatly it goes to the first one. With the 3.2.3, no issue, the chaser starts with the first one.
5243
PluginFehlerberichtMediumModbus TCP Coil Eingang wird nicht im InputAssignment n...Neu3.2.308.01.202412.01.2024 Task Description
Die Werte im Modbus Server werden über den Ausgang korrekt gesetzt, über den Eingang allerdings nicht eingelesen.
Im InputAssignment wurden folgende Tests durchgeführt:
1. Test: Tastatureingabe als Eingang und Modbus Coil 1000 als Ausgang → OK
2. Test: Modbus Coil 1001 als Eingang und Gernal_Blackout als Ausgang → NIO
3. Test: Modbus Coil 1001 als Eingang und Modbus Coil 1000 als Ausgang → NIO
5225
SoftdeskFehlerberichtMediumDropdown Menü steckt festNeu3.3 RC x28.12.202330.12.2023EDER Task Description
5132
GUI & ServerFehlerberichtMediumAbsturz der GUI nach Ändern der IP-Adresse des Server-P...Unbestätigt3.3 Beta x28.08.202329.09.2023LightningBrothers Task Description
5083
GUI & ServerToDoMediumAbfrage einbauen, ob ungespeicherte Änderungen noch ges...Unbestätigt3.3 Beta x3.3.x28.06.202301.08.2025LightningBrothers Task Description
  • Projekt schließen direkt in der Menüleiste
  • Projekt schließen in der PA beim aktiven Projekt
  • Beim Laden eines neuen Projekts
  • Beim Laden eines neuen Projekts im Kernel über Komandozeilenabfrage
5066
AudioAnalyserFehlerberichtMediumAudioAnalyzer Graph wird nicht richtig gespeichertNeu3.2.325.06.202325.06.2023 Task Description
  1. Aus Eingänge/Audio Analyzer/Spectrum/Spectrum X verschiedene Frequenzbänder in den Graphen einfügen,
  2. mit anderen Komponenten verbinden
  3. Projekt speichern
  4. Projekt laden
  5. Es ploppt eine Fehlermeldung auf: “Graphs wird geladen” ⇒ “Links können nicht in Graph geladen werden”
  6. “Ignorieren” auswählen
  7. Graph öffnen
  8. Die Spectrum-Komponenten des AudioAnalyzers sind nicht mehr mit anderen Komponenten verbunden
  • Verwenden von DMXControl 3.2.3
  • Wurde der Fehler bereits gemeldet? - Ich denke nicht
  • Ich kann keine Dateien anhängen.
LOG
17:48:42 WARN  ProjectManager - Error when loading Project Temp\c1befaac-c720-475c-9bf3-383b87917310.tmp: Warnings in Project
17:48:42 WARN  LumosTools - Loading Graphs in Project
17:48:42 WARN  LumosTools - Unable to load Links in Graph in Copy of Connection set
17:48:42 INFO  InputManager - Processing of Graph Copy of Connection set took 33ms
5000
20%
GUI & ServerFehlerberichtMediumColor Master fadet über weiß bei Wechsel der Fanning-Op...Benötigt Tests3.3 Beta x3.3.x30.12.202201.08.2025LightningBrothers Task Description
4910
GUI & ServerFehlerberichtMediumStrobe Type nicht wählbar bei Nutzung von Speedmaster f...Neu3.2.314.09.202214.09.2022 Task Description
Bei Fixtures mit unterschiedlichen Strobe Funktionen (z.B. Linear, Random, Pulse, Reverse Pulse) werden diese (in der Geräte Gruppe oder auch im Gerät selbst) korrekt dargestellt und bei manueller Bedienung auch korrekt angesprochen.
Wird die Feste Frequenz nun durch einen Speedmaster ersetzt, wird diese Frequenz ausschließlich auf die lineare Strobe Funktion angewandt. Die Auswahl des Typs ist in diesem Fall geleert.
Siehe auch Forum Thread https://forum.dmxcontrol-projects.org/index.php?thread/16745-unterschiedliche-strobe-eigenschaft-von-ger%C3%A4tegruppe-per-softdesk-steuern/
Showing tasks 1 - 50 of 661 Page 1 of 14
