4668 | |
4780 | |
4785 | |
4813 | |
–> Cuelist Monitor ist leer…
4829 | |
4840 | |
4896 | |
4903 | |
FS#3852
4953 | |
4970 | |
5092 | |
5094 | |
5111 | |
5114 | |
5131 | |
5190 | |
5260 | |
5267 | |
3216 | |
4335 | |
5119 | |
5235 | |
5224 | |
5065 | |
3070 | |
Geiler Scheiß, fast fertig….
3296 | |
4026 | |
5083 | |
5152 | |
303 | |
2430 | |
<zoom dmxchannel="19" >
<rotation dmxchannel="20" >
</rotation>
<index dmxchannel="20" />
</range>
</zoom>
2618 | |
2671 | |
2763 | |
3554 | |
3662 | |
3802 | |
3803 | |
4401 | |
4537 | |
4574 | |
4705 | |
RGB+ Kanäle Visualisieren
4708 | |
DMXControl
4782 | |
4803 | |
4805 | |
Zum aufräumen im SpeedMaster
4812 | |
4848 | |
4927 | |
4937 | |
