280 | |
478 | |
Cue 1 | manual | | |
Cue 2 | manual | | |
Cue 3 | follow | 1 | |
Cue 4 | follow | 1 | |
Cue 5 | follow | 1 | |
Cue 7 | manual | | |
479 | |
491 | |
492 | |
2975 | |
595 | |
3201 | |
Hallo liebe DMXControler,
LG Jelu
4809 | |
5073 | |
5137 | |
3527 | |
548 | |
4860 | |
490 | |
614 | |
725 | |
726 | |
728 | |
811 | |
MIDI Timecode
1067 | |
1805 | |
Color
Wheelrotation, Random
Prisma
Rotationen
Virtuelles Farbrad
Splitfarben
Zoom, Focus, Iris, Frost
Blendenschieber
Farbtemperatur
1. Slot auf dem Farbrad
RGB+ Geräte
Nebel
1810 | |
2046 | |
2239 | |
MfG Qasi
2429 | |
2462 | |
H L|H L|H L
B3 |Byte2 |Byte1
2617 | |
2619 | |
2632 | |
2765 | |
2910 | |
3149 | |
Art des Plugins (Kernel, GUI)
Author
Plugin-Version
kompatible DMXControl-Version
3264 | |
Block 1, Szene 1
Block 1, Szene 2
Block 1, Szene 3
Block 2, Szene 1
Block 2, Szene 2
Block 3, Szene 1
Block 3, Szene 2
Block 3, Szene 3
Block 3, Szene 4
3645 | |
4088 | |
4116 | |
4081 | |
1497 | |
4893 | |
4065 | |
s. Screenshot
4093 | |
4101 | |
4754 | |
Bin da offen für Vorschläge.
Prio. ganz niedrig…
4823 | |
4950 | |
4982 | |
4997 | |
3635 | |
3731 | |
