IDProgressCategoryTask TypeSeveritySummaryStatus  ascReported InDue In VersionOpenedLast EditedOpened by
4435
3360
  1. Create Cuelist
  2. Add Device
  3. Create Cuelist Group
  4. Create Device Group
  5. Create Executor Page
  6. Add Softdesk
  7. Add Power Source
  8. Create Stage View
  9. Create Item List
  10. Import Files
4778
