IDProgressCategoryTask TypeSeveritySummaryStatusReported InDue In VersionOpenedLast Edited  ascOpened by
4778
3360
  1. Create Cuelist
  2. Add Device
  3. Create Cuelist Group
  4. Create Device Group
  5. Create Executor Page
  6. Add Softdesk
  7. Add Power Source
  8. Create Stage View
  9. Create Item List
  10. Import Files
4435
