IDProgressCategoryTask TypeSeveritySummaryStatusReported InDue In Version  descOpenedLast EditedOpened by
3360
  1. Create Cuelist
  2. Add Device
  3. Create Cuelist Group
  4. Create Device Group
  5. Create Executor Page
  6. Add Softdesk
  7. Add Power Source
  8. Create Stage View
  9. Create Item List
  10. Import Files
4778
4435
